    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 55.7k Views 32 Watching
    • erikBE
      erikB
      Didier, thanks very much this is really a very handy ruby !!
      Now if there was an option for windows it would be fantastic. As far as I am concerned it also could be a 'standard' height for the distance of the floor and height of the lintel. This often changes during the design anyway and can easy be changed with push/pull afterwards.
      erikB
      • I
        ilay7k
        ErikB, magic cutting_windows-script(by Didier...again 😉) will be useful for you!
        • JClementsJ
          JClements
          It does nothing for me. I input a door height of 6', click OK, and that is it. The script ends.door_lentel error.jpg. The same thing happens whether the walls are preselected or not.
          • david_hD
            david_h
            I just gave this one a test drive. Works Great. huge Time saver.
            Merci, Mon ami.
            D
              @jclements said:
              It does nothing for me. I input a door height of 6', click OK, and that is it. The script ends.[attachment=0:3m6z38nq]<!-- ia0 -->door_lentel error.jpg<!-- ia0 -->[/attachment:3m6z38nq]. The same thing happens whether the walls are preselected or not.
              What happens if you enter 72 for the height?
              • majidM
                majid
                it doesn't work for me too 😞 .nothing happens! i saw the swf , but i don't know where i am rong!!
                • I
                  ilay7k
                  "door.skp" example with description was included in package(From: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/door_lintel.zip)
                  • majidM
                    majid
                    thanx .... it was so useful 👍 (none of the smilies shows my respect truely )
                      dylan
                      Excellent Didier, thankyou for this 👍
                      http://dmdarchitecture.co.uk/
                      • EdsonE
                        Edson
                        i managed to install it but i do not know how to make it work.
                        what is the 1st thing to do? set the door height? and then what? could you take me through the steps?
                        http://www.mahfuz.arq.br
                          dylan
                          Edson check out ilay7k's post three up from yours. There is a link to a skp explaining.
                          • EdsonE
                            Edson
                            thanks, dylan. but that is not what i asked for.
                              Edson, I set the door height, selected the side of the door opening and then chose the other option in the plugin's menu.
                              • EdsonE
                                Edson
                                this is what happens when i run the script. notice there is no lintel. the result was just the disapearance of a back face and the shortening of the wall on the side where i selected a face to start the lintel from.
                                small room with a door before running the script
                                small room with a door AFTER running the script:
                                  Edson, is that your back face color?. Try this. Before pulling the walls up, delete the floor so the walls pull up right side out.
                                  • EdsonE
                                    Edson
                                    thanks, dave. i ran some tests and the problem seems to have been the fact that the faces were reversed for the script to work. leaving the floor on was no problem.
                                      Edson, I knew that reversing the faces would fix it but if you had deleted the floor, Push/Pull wouldn't have resulted in the exposed back faces. Glad you got it to work in any case.
                                      • E
                                        enhorning
                                        I installed, it showed up in the plugins menu, all seemed well. I draw a simple floor plan and when I select a face and run door by embasure it crashes SU instantly.
                                        Any ideas?
                                        marianne
                                        • I
                                          ilay7k
                                          Hello Marianne!
                                          Try to catch messages from ruby-console(open console, do some actions with script and look at console, what happens...)
                                          Will be nice to have bugsplat-log with ruby?
                                          • Didier BurD
                                            Didier Bur
                                            Of course, because the script uses the normal vector of the selected face to decide in which direction it has to pushpull the lintel.
                                            DB
                                            • 1 / 4
