    Just Released! Subdivide and Smooth
    extensions
    102 Posts 36 Posters 24.5k Views 36 Watching
      todd burch
      Looking very CUSHY there krash!! VERY Cushy!
      • W Offline
        Whaat
        @krash88 said:
        I've tried it every way that I can imagine; top, front, side, perspective, on every type of geometry; flat 2d, 3d cubes, etc. It always offsets the cut when I try to snap it to an endpoint.
        Yep, this is some sort of bug. I'll look into but don't expect a quick fix. Thanks for purchasing!
        • W Offline
          Whaat
          @osx59 said:
          hello Whaat,
          I bought script, but it does not function on my macbook 2,2 Ghz and 4Go fo mem !
          on Sketchup Pro 6.0 (6.4.245)
          😒 😞 πŸ‘Š
          V
          It sounds like an installation problem. You should have ONE file in your plugins folder called 'subsmooth_loader.rb'.
          You should have ONE folder in your plugins folder called 'Subsmooth'.
          The contents of the folder should be as shown in the attached image. Hope this solves the problem!
          contents of subsmooth folder
            cruelcomedy
            thank you for this plugin. its amazing
            http://www.richarddoble.com/
            • W Offline
              Whaat
              I've seen your work. I can't wait to see what you can do with this plugin! Don't be shy about posting your amazing skills!
              • Alan FraserA Offline
                Alan Fraser
                I can't believe I missed the launch date. Oh well, got it now. Many thanks Dale. I can't wait to try this out on developing low-poly people from the ground up.
                Well a few minutes work plus a little post processing got me as high as the thighs, at least. A truly great plugin.
                3D Figures
                • RayOchoaR Offline
                  RayOchoa
                  I JUST GOT IT YESTERDAY!!!!! im so exited what should i do first
                  CaR DeSiGnS bY mE
                  http://ray-ochoa.com
                  • H Offline
                    HFM
                    Okay, I really like this script, but I have a few questions:
                    At home, I've got a pretty decent pc [dual core 6400 cpu, 8800 gts and two gigs of ram]
                    and the thing that worries me is that after subdividing one object, SU isn't running as smooth as it should. Can anyone give me some info on this? what system you are running and how easy SU handels multiple subdivided objects [1 or 2 in subdivision off course]
                    Well, that's actually one question, but an important one
                    money is no problem, with the 'stable' US dollar I'm paying about 2 euro's here 🀣
                    maybe one other question: I've got two other plugins running, V-ray and Sketchyphysics [read: cool and fun ^^] are there any known conflicts?
                    Thanx in advance
                    Hugo
                      remus
                      Subd and smoothing is quite a taxing operation for any system, so i wouldnt be surprised if your machine slows down. Ive got an E6750 with 4 gigs of ram and i can quite easily grind it to a halt with a reasonably high poly model and a couple of smoothing iterations.
                      With respect to the conflicts, i think a few people were having problems with Vray, but that might have been sorted out by now. Id jsut keep an eye out on the forum really and see if anyone comes up with any solutions.
                      • H Offline
                        HFM
                        Thnx for the info πŸ‘
                        • W Offline
                          Whaat
                          There are two things that could cause SU to run slower:
                          1. Viewport navigation becomes slower due to higher number of polys displayed. This is a limitation of your computer hardware and of SU itself. A high-end video card would definitely help.
                          2. If you are modelling using proxy subdivision and you have auto-update turned on, the updating may be causing SU to run slow (for example, if you paint the faces of a proxy, it will update each time you paint a face). However, if you are not currently editing the proxy, SU should run at normal speed. Turning auto-update off should also return SU to normal speed.
                          Hope this helps.
                          • H Offline
                            HFM
                            Hope this helps.
                            It helped and I've bought it ^^ still figuring out how to 'install' it πŸ˜„
                            for the people still not too sure off buying it:
                            http://img410.imageshack.us/img410/5834/glassyhn9.png
                            2 minutes of messing around 😍
                            [right click, view for full size...]
                              Jorgensen
                              WOW 😲
                              • Z Offline
                                ZYX
                                Thanks Whaat! I have done some test and found this very useful. Here is one of them:
                                  GUNAWAN W
                                  just bought the script today.
                                  hope will work on my desktop
                                  • RayOchoaR Offline
                                    RayOchoa
                                    That's great what do you plan on using it for?
                                    CaR DeSiGnS bY mE
                                      GUNAWAN W
                                      trying to rebuild my furniture collection
                                      thank's to whaat that make this script available. πŸ‘ πŸ‘
                                      this is what i mean
                                      Before
                                      After
                                      • spenceS Offline
                                        spence
                                        Purchased, and this is so cool! I have to start messing around.
                                        Spence
                                        • mariochaM Offline
                                          mariocha
                                          Here is my way of thanking you for that Whaat an amazing plugin.
                                          Plain SU, done with Sub-Smooth and FDD. They just complete each other so very well !!
                                          %(#008000)[Mario C.
                                            Creasia
                                            David,
                                            I was impressed with the practicality and usability of the Indigo exporter, but Subdivide and Smooth really corners the market! I use this method in Studio Max all the time for character modeling, and I can't wait to try it in SU.
                                            Google needs to hire you full time with a huge salary!
                                            • 4 / 6
