    Just Released! Subdivide and Smooth
    extensions
    102 Posts 36 Posters 28.6k Views 36 Watching
      remus
      My bad, where you in a specific view (top, bottom, left etc)? if notits worth trying that, as ive found that can also cause problems.
        krash88
        I've tried it every way that I can imagine; top, front, side, perspective, on every type of geometry; flat 2d, 3d cubes, etc. It always offsets the cut when I try to snap it to an endpoint. I hope this can be a quick fix(hopefully I'm just doing something wrong). My employer is, as well as myself, VERY impressed with what this script can do and I'm itching to finish my first model!
          Masta Squidge
          Oh hell I bought it. I havent even used SU in like three weeks and I bought it anyways lol.
          Maybe ill have more incentive to play with SU.
            krash88
            Despite my problems with the knife tool, I just demonstrated to my employer how I can now create a seat cushion that normally takes about an hour by hand, in 5 minutes with the help of this script. This, combined with CPhillips FFD script, has made my day and paid for itself in less than an hour!
            http://i109.photobucket.com/albums/n65/krash88/cush.jpg
            Thanks again! πŸ˜„
              todd burch
              Looking very CUSHY there krash!! VERY Cushy!
              • W Offline
                Whaat
                Yep, this is some sort of bug. I'll look into but don't expect a quick fix. Thanks for purchasing!
                • W Offline
                  Whaat
                  @osx59 said:
                  hello Whaat,
                  I bought script, but it does not function on my macbook 2,2 Ghz and 4Go fo mem !
                  on Sketchup Pro 6.0 (6.4.245)
                  😒 😞 πŸ‘Š
                  V
                  It sounds like an installation problem. You should have ONE file in your plugins folder called 'subsmooth_loader.rb'.
                  You should have ONE folder in your plugins folder called 'Subsmooth'.
                  The contents of the folder should be as shown in the attached image. Hope this solves the problem!
                  contents of subsmooth folder
                    cruelcomedy
                    thank you for this plugin. its amazing
                    http://www.richarddoble.com/
                    • W Offline
                      Whaat
                      I've seen your work. I can't wait to see what you can do with this plugin! Don't be shy about posting your amazing skills!
                      • Alan FraserA Offline
                        Alan Fraser
                        I can't believe I missed the launch date. Oh well, got it now. Many thanks Dale. I can't wait to try this out on developing low-poly people from the ground up.
                        Well a few minutes work plus a little post processing got me as high as the thighs, at least. A truly great plugin.
                        3D Figures
                        • RayOchoaR Offline
                          RayOchoa
                          I JUST GOT IT YESTERDAY!!!!! im so exited what should i do first
                          CaR DeSiGnS bY mE
                          http://ray-ochoa.com
                          • H Offline
                            HFM
                            Okay, I really like this script, but I have a few questions:
                            At home, I've got a pretty decent pc [dual core 6400 cpu, 8800 gts and two gigs of ram]
                            and the thing that worries me is that after subdividing one object, SU isn't running as smooth as it should. Can anyone give me some info on this? what system you are running and how easy SU handels multiple subdivided objects [1 or 2 in subdivision off course]
                            Well, that's actually one question, but an important one
                            money is no problem, with the 'stable' US dollar I'm paying about 2 euro's here 🀣
                            maybe one other question: I've got two other plugins running, V-ray and Sketchyphysics [read: cool and fun ^^] are there any known conflicts?
                            Thanx in advance
                            Hugo
                              remus
                              Subd and smoothing is quite a taxing operation for any system, so i wouldnt be surprised if your machine slows down. Ive got an E6750 with 4 gigs of ram and i can quite easily grind it to a halt with a reasonably high poly model and a couple of smoothing iterations.
                              With respect to the conflicts, i think a few people were having problems with Vray, but that might have been sorted out by now. Id jsut keep an eye out on the forum really and see if anyone comes up with any solutions.
                              • H Offline
                                HFM
                                Thnx for the info πŸ‘
                                • W Offline
                                  Whaat
                                  There are two things that could cause SU to run slower:
                                  1. Viewport navigation becomes slower due to higher number of polys displayed. This is a limitation of your computer hardware and of SU itself. A high-end video card would definitely help.
                                  2. If you are modelling using proxy subdivision and you have auto-update turned on, the updating may be causing SU to run slow (for example, if you paint the faces of a proxy, it will update each time you paint a face). However, if you are not currently editing the proxy, SU should run at normal speed. Turning auto-update off should also return SU to normal speed.
                                  Hope this helps.
                                  • H Offline
                                    HFM
                                    Hope this helps.
                                    It helped and I've bought it ^^ still figuring out how to 'install' it πŸ˜„
                                    for the people still not too sure off buying it:
                                    http://img410.imageshack.us/img410/5834/glassyhn9.png
                                    2 minutes of messing around 😍
                                    [right click, view for full size...]
                                      Jorgensen
                                      WOW 😲
                                      • Z Offline
                                        ZYX
                                        Thanks Whaat! I have done some test and found this very useful. Here is one of them:
                                          GUNAWAN W
                                          just bought the script today.
                                          hope will work on my desktop
                                          • RayOchoaR Offline
                                            RayOchoa
                                            That's great what do you plan on using it for?
                                            CaR DeSiGnS bY mE
                                            • 3 / 6
