    [Plugin] Skin.rb
    237 Posts 66 Posters 199.4k Views 66 Watching
    • N Offline
      NewOne
      @lorca said:
      Is this the same/different plugin by author D. Belvin?
      Have no idea... I just look for a "skin" plugin that works well.
      • W Offline
        windman
        i tried to use this plugin to skin my rc sailplane fuselage formers. i could not manage it to work anyway.
        then i draw simple squares on same axis to try. i tried to skin between two shapes, but nothing works. something i did should be wrong i guess.
        • utilerU Offline
          utiler
          Or Kirill2008's wonders!!!
          [Plugin] 2 Faces + Path - http://forums.sketchucation.com/viewtopic.php?f=180&t=21658
          [Plugin] Blend - http://forums.sketchucation.com/viewtopic.php?f=180&t=21134
          Just Curious...
            It would appear that the author of the Skin plugin has moved on to other things or for whatever reason has no interest in making his plugin work correctly. Chris Fullmer has done an excellent plugin called Loft that does work and, I think, does a nicer job anyway. Why not just use it instead?
              aea
              my non works .
                I wonder what it is about this plugin that gives so many people such a hard time. It works just fine for me.
                • mitcorbM Offline
                  mitcorb
                  My copy of skin.rb seems to work fine.
                  In my case, I have both skin.zip and skin23.zip in my plugins folder. There is a skin folder residing in the plugins folder that contains menu button png's.
                  Again, in my case, I installed skin first, then I installed skin23. I guess this process has something to do with it.
                  No guarantees.
                  • utilerU Offline
                    utiler
                    Dave, I think it is because there are a number of versions right throughout the thread..... I too had trouble. So much so, i removed it all together.....
                    Just Curious...
                    • Bob JamesB Offline
                      Bob James
                      I thought the ground rule was to put the latest version on the first page of the thread. 😉
                      • utilerU Offline
                        utiler
                        me too.....
                        Just Curious...
                        • mitcorbM Offline
                          mitcorb
                          At the time that this ruby was published, the ground rule was not yet being discussed. Not too long after(relative phrase)I joined the forum, I observed the dialogue turning to making the postings of plugins more standard to reduce confusion. This thread predated that consensus.
                          What I wish somebody would do is either contact the author and have him get the kinks out, or get his permission to allow someone else to fix it, or scrap it and start over.
                          There is considerable value in the concept of a relatively simple tool such as this, when you don't need some of those others with more functionality.
                          Right now, I couldn't Ruby my way out of a brown paper bag, let alone fix Skin.
                          • utilerU Offline
                            utiler
                            I'm trying to get out the same browm pape bag... 😉
                            I really feel fortunate to have be in the company of many generous SU'er..... 🎉
                            Just Curious...
                            • fredo6F Offline
                              fredo6
                              If you are not too much in a hurry, I am preparing a script that will do mass skinning (as well as some loft generation). It's far from being ready, probably a month or so away.
                              Attached is a SKP showing the typical situations where it may be useful. For skinning, you typically select the whole wireframe and let it go (there is a more accurate interactive mode however).
                              I still have a lot to do on the algorithms and on the UI. So, no very firm promise on a timeframe actually!
                              Fredo
                              1 SKP file enclosed (SU 6 format)
                              • mitcorbM Offline
                                mitcorb
                                Fredo:
                                Your preview looks very promising. I think a lot of people here would be interested in this multitool. Thanks for the peek.
                                  Skin loft in folish ! 😲 ☀ 😎
                                    chrisjk
                                    This will be a superb tool - looking forward very much to it!
                                    Chris
                                      dedmin
                                      Fredo
                                      • plot-parisP Offline
                                        plot-paris
                                        oh yes, that looks really promising! looking forward to the first script! 🎉
                                          Fredo strikes again ❗
                                          Looks set to knock my EEbyRails into a [proverbial] cocked hat ☀
                                          Please get this up and running as soon as possible... 🎉
                                          • utilerU Offline
                                            utiler
                                            Fredo, isn't this similar to what Kirill2008 has developed?
                                            see here - http://forums.sketchucation.com/viewtopic.php?f=323&t=21658&hilit=plugin
                                            Just Curious...
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 11 / 12
