    [Plugin] Skin.rb
    237 Posts 66 Posters 205.7k Views 66 Watching
    • Bob JamesB
      Bob James
      @christian_dl said:
      As I found out. The ..L.png's are for Windows. The ..S.png's are for OSX.
      The Smoothing Option is not implemented, because the Author promised this for a Version 3. See a Posting in this Thread before.
      Regards Christian
      Thanks for the investigation report: now it makes sense that only three icons show (and that I should be patient and wait for version 3 for smoothing).
      • utilerU
        utiler
        Speaking of the author, has anyone see the him around...? 😕
        Just Curious...
        • ToboboT
          Tobobo
          I noticed his profile pic has changed recently.
          Toby
          Philippians 4:13
          • ToboboT
            Tobobo
            @tobobo said:
            I hope we have scared him off?
            You might want to add the word "not" in there. 😒
            Yeah thanks Coen. I've changed the post but i can be so dense. 😳
            Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through,
            Toby
            Philippians 4:13
            • N
              NewOne
              Sorry, what version is the final one? I tried Skin 2.2, but I remember that a few weeks ago I found a version that included som kind of line division in smaller segments.
              Thank you.
              • L
                lorca
                Is this the same/different plugin by author D. Belvin?
                • N
                  NewOne
                  Have no idea... I just look for a "skin" plugin that works well.
                  • W
                    windman
                    i tried to use this plugin to skin my rc sailplane fuselage formers. i could not manage it to work anyway.
                    then i draw simple squares on same axis to try. i tried to skin between two shapes, but nothing works. something i did should be wrong i guess.
                    • utilerU
                      utiler
                      Or Kirill2008's wonders!!!
                      [Plugin] 2 Faces + Path - http://forums.sketchucation.com/viewtopic.php?f=180&t=21658
                      [Plugin] Blend - http://forums.sketchucation.com/viewtopic.php?f=180&t=21134
                      Just Curious...
                        It would appear that the author of the Skin plugin has moved on to other things or for whatever reason has no interest in making his plugin work correctly. Chris Fullmer has done an excellent plugin called Loft that does work and, I think, does a nicer job anyway. Why not just use it instead?
                          aea
                          my non works .
                            I wonder what it is about this plugin that gives so many people such a hard time. It works just fine for me.
                            • mitcorbM
                              mitcorb
                              My copy of skin.rb seems to work fine.
                              In my case, I have both skin.zip and skin23.zip in my plugins folder. There is a skin folder residing in the plugins folder that contains menu button png's.
                              Again, in my case, I installed skin first, then I installed skin23. I guess this process has something to do with it.
                              No guarantees.
                              • utilerU
                                utiler
                                Dave, I think it is because there are a number of versions right throughout the thread..... I too had trouble. So much so, i removed it all together.....
                                Just Curious...
                                • Bob JamesB
                                  Bob James
                                  I thought the ground rule was to put the latest version on the first page of the thread. 😉
                                  • utilerU
                                    utiler
                                    me too.....
                                    Just Curious...
                                    • mitcorbM
                                      mitcorb
                                      At the time that this ruby was published, the ground rule was not yet being discussed. Not too long after(relative phrase)I joined the forum, I observed the dialogue turning to making the postings of plugins more standard to reduce confusion. This thread predated that consensus.
                                      What I wish somebody would do is either contact the author and have him get the kinks out, or get his permission to allow someone else to fix it, or scrap it and start over.
                                      There is considerable value in the concept of a relatively simple tool such as this, when you don't need some of those others with more functionality.
                                      Right now, I couldn't Ruby my way out of a brown paper bag, let alone fix Skin.
                                      • utilerU
                                        utiler
                                        I'm trying to get out the same browm pape bag... 😉
                                        I really feel fortunate to have be in the company of many generous SU'er..... 🎉
                                        Just Curious...
                                        • fredo6F
                                          If you are not too much in a hurry, I am preparing a script that will do mass skinning (as well as some loft generation). It's far from being ready, probably a month or so away.
                                          Attached is a SKP showing the typical situations where it may be useful. For skinning, you typically select the whole wireframe and let it go (there is a more accurate interactive mode however).
                                          I still have a lot to do on the algorithms and on the UI. So, no very firm promise on a timeframe actually!
                                          1 SKP file enclosed (SU 6 format)
                                          • mitcorbM
                                            mitcorb
                                            Fredo:
                                            Your preview looks very promising. I think a lot of people here would be interested in this multitool. Thanks for the peek.
                                            • 11
                                            • 12
                                            • 11 / 12
