    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 831.0k Views 667 Watching
      Hi Andrew,
      Enjoy the adventure. Don't be afraid to post if you've difficulties or just want to showoff 😉
      Word of warning - there's a member called Gaieus who's a bit deranged. No doubt he'll poke his head in at some stage!
        Ha! Look who is speaking!
          See.... 😒
          Betelgaieus, Betelgaieus, Betelgaieus and whoosh......
            I would not speak with such an avatar! 😒
              spost
              Hi! I'm new to Sketchup and this forum... it's already been helpful.
              Thanks!
              • F Offline
                FoxLogan
                http://www.youtube.com/watch?v=4Y6Rn3CusRc&feature=youtube_gdata for those who use sketchup for imvu i made a tutorial at the end of last year which shows you from start to finish and even importing it to imvu. the video is under 6 minute but very easy to follow, if you would like to know anything else dont be afraid to contact me
                  mingjae
                  hi it's me again,
                  until today, I have watched some tutorial video in youtube which suggested here. thx
                  there also a problem I could not solve, maybe you can help me?
                  it's a simple problem, just want to make a ramp, but a "J" shaped ramp,
                  I tried curvishear plugin but it seems not much help.
                  this is the priview:
                  http://img834.imageshack.us/img834/6261/bingung.jpg
                  i explode it and clean all the lines inside the ramp and push a little, and then select one edge line and move it in Z direction (it works if only straight ramp, not j shaped)
                  could somebody help me? 😢
                  • mitcorbM Offline
                    mitcorb
                    Hi, mingjae:
                    For some reason, I cannot see your image preview. Could you post again?
                      mingjae
                      umm sorry, here it is:
                      http://img843.imageshack.us/img843/6261/bingung.jpg
                      I can make a ramp if its not a "J" shaped (see section pic).
                      I want to make a ramp from level A to level B, can you help me
                      (it doesn't matter if the lines inside is clear)
                      thx
                      • mitcorbM Offline
                        mitcorb
                        Your surfaces appear to be back faces, or reversed. This may affect how Curvishear behaves. Change the faces and see if this helps. Also, in the first image, it appears that the J is two separate groups?
                        I am seeing if I can make the ramp...
                        EDIT:
                        Ok. I used Curvishear to make a ramp resembling yours. It is not metric. All dimensions assumed. Curvishear refused to skin for me, as Fredo6 warned in his Curvishear thread.
                        You need to pick two welded curves, in this case, the continuous left edge and right edge of the ramp to run Curvishear. The upper inside radius was incorrect result, so I used Arc tool with inferencing to correct the curve. I also had to draw the faces of the curves with diagonals then move these vertices to the new arc vertices. Then I copymoved these faces down an assumed distance for thickness and made the faces piece by piece.
                        Please see attachment with hidden lines visible.
                        I don't know if this helps. 😕
                          mingjae
                          woow, great! it works!
                          thanks mitcorb! almost forget the weld plugins (make a polyline) and skinning with curviloft!
                          (note: if you pull the edge line to make the ramp elevation(will pull/stretch all connecting lines), it wont works well, you will make a contour in the ramp, but using curvishear it result a great ramps! )
                          thanks SketchUcation
                          • mitcorbM Offline
                            mitcorb
                            @mingjae:
                            I am glad you found a solution, and you responded back. I send my best wishes to you for success.
                            It is best to post problems with specific plugins in the thread for that plugin. For instance, Curvishear. Fredo6 usually responds, as will others who have significant practice with the tool.
                            While you thank Sketchucation, be sure to thank Fredo6 and others, who are very generous in offering these tools to the community. And, while I am at it, thank you Fredo6, and thank you Sketchucation!! 💚
                            • mitcorbM Offline
                              mitcorb
                              Hi, mingjae:
                              I forgot to suggest caution on the "breakover" angle where slope meets level. I think this should not exceed about 7 degrees. Otherwise, the vehicle undercarriage may collide with the pavement.
                                Djarlo
                                Its nice, but it has a way to high poly-count for what you are trying to use it. when using the curve tool reduce the ammount of segments, by changing the number bottom/right of the window.
                                  rmendiola
                                  hi
                                  my name is raul
                                  and thanks for the warm welcome.
                                  regards
                                    Well, welcome then Raul! ☀
                                    • V Offline
                                      viewtop1
                                      Hi Guys
                                      Just getting started with sketchup, no design backround whatsoever, but enjoying it
                                      Cheers
                                      Cornelis
                                        Welcome Cornelius,
                                        Enjoy the 3d adventure and feel free to post any difficulties you encounter.
                                        Rich
                                          designerstuart
                                          hello i've been a member for a while but not made any posts..... hoping to learn some good tricks in sketchup and i guess some rendering tips would be useful.
                                            Hi Stuart and "welcome" (if I can say this to a member almost here for a year).
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 72
                                            • 73
                                            • 44 / 73
