    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 1.5m Views 667 Watching
    • mitcorbM
      mitcorb
      Your surfaces appear to be back faces, or reversed. This may affect how Curvishear behaves. Change the faces and see if this helps. Also, in the first image, it appears that the J is two separate groups?
      I am seeing if I can make the ramp...
      EDIT:
      Ok. I used Curvishear to make a ramp resembling yours. It is not metric. All dimensions assumed. Curvishear refused to skin for me, as Fredo6 warned in his Curvishear thread.
      You need to pick two welded curves, in this case, the continuous left edge and right edge of the ramp to run Curvishear. The upper inside radius was incorrect result, so I used Arc tool with inferencing to correct the curve. I also had to draw the faces of the curves with diagonals then move these vertices to the new arc vertices. Then I copymoved these faces down an assumed distance for thickness and made the faces piece by piece.
      Please see attachment with hidden lines visible.
      I don't know if this helps. 😕
        mingjae
        woow, great! it works!
        thanks mitcorb! almost forget the weld plugins (make a polyline) and skinning with curviloft!
        (note: if you pull the edge line to make the ramp elevation(will pull/stretch all connecting lines), it wont works well, you will make a contour in the ramp, but using curvishear it result a great ramps! )
        thanks SketchUcation
        • mitcorbM
          mitcorb
          @mingjae:
          I am glad you found a solution, and you responded back. I send my best wishes to you for success.
          It is best to post problems with specific plugins in the thread for that plugin. For instance, Curvishear. Fredo6 usually responds, as will others who have significant practice with the tool.
          While you thank Sketchucation, be sure to thank Fredo6 and others, who are very generous in offering these tools to the community. And, while I am at it, thank you Fredo6, and thank you Sketchucation!! 💚
          • mitcorbM
            mitcorb
            Hi, mingjae:
            I forgot to suggest caution on the "breakover" angle where slope meets level. I think this should not exceed about 7 degrees. Otherwise, the vehicle undercarriage may collide with the pavement.
              Djarlo
              @foxlogan said:
              http://www.youtube.com/watch?v=4Y6Rn3CusRc&feature=youtube_gdata for those who use sketchup for imvu i made a tutorial at the end of last year which shows you from start to finish and even importing it to imvu. the video is under 6 minute but very easy to follow, if you would like to know anything else dont be afraid to contact me
              Its nice, but it has a way to high poly-count for what you are trying to use it. when using the curve tool reduce the ammount of segments, by changing the number bottom/right of the window.
                rmendiola
                hi
                my name is raul
                and thanks for the warm welcome.
                regards
                • GaieusG
                  Well, welcome then Raul! ☀
                  • V
                    viewtop1
                    Hi Guys
                    Just getting started with sketchup, no design backround whatsoever, but enjoying it
                    Cheers
                    Cornelis
                      Welcome Cornelius,
                      Enjoy the 3d adventure and feel free to post any difficulties you encounter.
                      Rich
                        designerstuart
                        hello i've been a member for a while but not made any posts..... hoping to learn some good tricks in sketchup and i guess some rendering tips would be useful.
                        • GaieusG
                          Hi Stuart and "welcome" (if I can say this to a member almost here for a year).
                            SketchySketch
                            Howdy ho, everyone! I'm Jean Marie and I'm a newbie to the forums and a newbie to Google Sketch-up. I utilize AUTOCad and Maya for many of my other 3-D needs, but I had never gotten around to using Google Sketch-up. Hopefully I'll learn a thing or two. Anyway, hope to meet everyone soon. 😄
                            • G
                              Goonster
                              Hi. My name is Goonster. Ive had Sketchup for a while now but still consider myself to be something of a newbie as far as the program is concerned. I like to use Paint.Net for making pictures and doing a bit of post processing of my SU work. I also have Gimp and Terragen 2 which is great for creating photo realistic landscapes. At the moment I am concentrating on making furniture to use in a house project Im doing and last week I uploaded my first two items to the 3D Warehouse. Hopefully I`ll learn even more during my stay here.
                              • O
                                Oskar
                                Hello you all!
                                I'd like to introduce myself. I live near Frankfurt (Germany) and like Sketchup since about 3 years, for profession as well as for private works (furniture and inner-buildings etc).
                                Now i found this forum... 👍 ...so i hope to get better.
                                I'm very sorry for my bad and childish english; i'm not used to it.
                                And i've got a stupid question, it's my first download of a ruby.
                                I think, i'm a typical layer-8-problem 💚 :
                                i downloaded 'shape bender' (thx to the programmer!), and as demanded 'progressbar'.
                                In the .zip, there is a lone-standing file named clf_shape_bender_loader.rb,
                                and in this file following is shown:
                                require 'sketchup.rb'
                                require 'extensions.rb'
                                require 'progressbar.rb'
                                Ok, the first means to activate the ruby-console, right?
                                But what does extensions mean? Another necessary download?
                                And do i have to unzip all, or just drag and drop this loader-file?
                                Thx for patience...
                                • GaieusG
                                  Hi Oskar and first of all, welcome!
                                  Extensions means that you will need to activate the plugin after you install it under Window > Preferences > Extensions. It also comes with a one-button toolbar that you can activate under View > Toolbars once you activated it and restarted SU.
                                  • O
                                    Oskar
                                    Good morning Gaieus,
                                    thank you for helping.
                                    Edit: And now it works. Great!
                                    I've never performed such an easy installation before!
                                      D_russ
                                      I just joined yesterday.
                                      My name is Diane and I use AutoCAD but would like to integrate Sketchup into my drawings.
                                      I mainly doing Subdivision and condo layouts and it would be great to see the buildings come to life.
                                      Any advice is welcome.
                                      • mitcorbM
                                        mitcorb
                                        Well, D_russ:
                                        While everyone else is napping, welcome.
                                        I am an Autocad user, too. But there are plenty of others here and they use a lot of other 2d and 3d programs, as I am sure you know.
                                        You just ask away. Take some time to become familiar with the Forum.
                                        • T
                                          TLD
                                          Hello People,
                                          Am so delighted to be part of this great forum...I came across a tutorial on a plugin called soap skin bubble...Wondering if I could get some assistance on how to get it...
                                          Thanks Guys!
                                          • I
                                            indrasukmab
                                            I have trouble when I try to login this forum...
                                            everytime I'll try to login always said "You have been banned from this board until Mon Apr 18, 2011 8:59 am.
                                            Please contact the Board Administrator for more information.
                                            A ban has been issued on your IP address."
                                            till now the solution for log in in this forum is browsing from ninjacloak.com
                                            can anybody help me?
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 72
                                            • 73
                                            • 44 / 73
