    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 869.2k Views 667 Watching
      Ha! Look who is speaking!
        See.... 😒
        Betelgaieus, Betelgaieus, Betelgaieus and whoosh......
          I would not speak with such an avatar! 😒
            spost
            Hi! I'm new to Sketchup and this forum... it's already been helpful.
            • F Offline
              FoxLogan
              http://www.youtube.com/watch?v=4Y6Rn3CusRc&feature=youtube_gdata for those who use sketchup for imvu i made a tutorial at the end of last year which shows you from start to finish and even importing it to imvu. the video is under 6 minute but very easy to follow, if you would like to know anything else dont be afraid to contact me
                mingjae
                hi it's me again,
                until today, I have watched some tutorial video in youtube which suggested here. thx
                there also a problem I could not solve, maybe you can help me?
                it's a simple problem, just want to make a ramp, but a "J" shaped ramp,
                I tried curvishear plugin but it seems not much help.
                this is the priview:
                http://img834.imageshack.us/img834/6261/bingung.jpg
                i explode it and clean all the lines inside the ramp and push a little, and then select one edge line and move it in Z direction (it works if only straight ramp, not j shaped)
                could somebody help me? 😢
                • mitcorbM Offline
                  mitcorb
                  Hi, mingjae:
                  For some reason, I cannot see your image preview. Could you post again?
                    mingjae
                    umm sorry, here it is:
                    http://img843.imageshack.us/img843/6261/bingung.jpg
                    I can make a ramp if its not a "J" shaped (see section pic).
                    I want to make a ramp from level A to level B, can you help me
                    (it doesn't matter if the lines inside is clear)
                    thx
                    • mitcorbM Offline
                      mitcorb
                      Your surfaces appear to be back faces, or reversed. This may affect how Curvishear behaves. Change the faces and see if this helps. Also, in the first image, it appears that the J is two separate groups?
                      I am seeing if I can make the ramp...
                      EDIT:
                      Ok. I used Curvishear to make a ramp resembling yours. It is not metric. All dimensions assumed. Curvishear refused to skin for me, as Fredo6 warned in his Curvishear thread.
                      You need to pick two welded curves, in this case, the continuous left edge and right edge of the ramp to run Curvishear. The upper inside radius was incorrect result, so I used Arc tool with inferencing to correct the curve. I also had to draw the faces of the curves with diagonals then move these vertices to the new arc vertices. Then I copymoved these faces down an assumed distance for thickness and made the faces piece by piece.
                      Please see attachment with hidden lines visible.
                      I don't know if this helps. 😕
                        mingjae
                        woow, great! it works!
                        thanks mitcorb! almost forget the weld plugins (make a polyline) and skinning with curviloft!
                        (note: if you pull the edge line to make the ramp elevation(will pull/stretch all connecting lines), it wont works well, you will make a contour in the ramp, but using curvishear it result a great ramps! )
                        thanks SketchUcation
                        • mitcorbM Offline
                          mitcorb
                          @mingjae:
                          I am glad you found a solution, and you responded back. I send my best wishes to you for success.
                          It is best to post problems with specific plugins in the thread for that plugin. For instance, Curvishear. Fredo6 usually responds, as will others who have significant practice with the tool.
                          While you thank Sketchucation, be sure to thank Fredo6 and others, who are very generous in offering these tools to the community. And, while I am at it, thank you Fredo6, and thank you Sketchucation!! 💚
                          • mitcorbM Offline
                            mitcorb
                            Hi, mingjae:
                            I forgot to suggest caution on the "breakover" angle where slope meets level. I think this should not exceed about 7 degrees. Otherwise, the vehicle undercarriage may collide with the pavement.
                              Djarlo
                              Its nice, but it has a way to high poly-count for what you are trying to use it. when using the curve tool reduce the ammount of segments, by changing the number bottom/right of the window.
                                rmendiola
                                hi
                                my name is raul
                                and thanks for the warm welcome.
                                regards
                                  Well, welcome then Raul! ☀
                                  • V Offline
                                    viewtop1
                                    Hi Guys
                                    Just getting started with sketchup, no design backround whatsoever, but enjoying it
                                    Cheers
                                    Cornelis
                                      Welcome Cornelius,
                                      Enjoy the 3d adventure and feel free to post any difficulties you encounter.
                                      Rich
                                        designerstuart
                                        hello i've been a member for a while but not made any posts..... hoping to learn some good tricks in sketchup and i guess some rendering tips would be useful.
                                          Hi Stuart and "welcome" (if I can say this to a member almost here for a year).
                                            SketchySketch
                                            Howdy ho, everyone! I'm Jean Marie and I'm a newbie to the forums and a newbie to Google Sketch-up. I utilize AUTOCad and Maya for many of my other 3-D needs, but I had never gotten around to using Google Sketch-up. Hopefully I'll learn a thing or two. Anyway, hope to meet everyone soon. 😄
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 72
                                            • 73
                                            • 44 / 73
