    [Plugin][$] FredoBend - v1.7a - 29 Nov 26
    82 Posts 16 Posters 22.9k Views 16 Watching
    • J
      jonorman
      Hi. Would editing radius be a possibility as well as angle ??
      fredo6F 1 Reply Last reply
      • fredo6F
        fredo6 @jonorman
        Yes. But are you sure you know what the radius value would be?
        J 1 Reply Last reply
        • J
          jonorman @fredo6
          @fredo6 Yes, it would be nice to either give angle value, or radius. Maybe following: If you change angel in the angle value, the radius automaticly update, and if you then if you change the radius value the angle value would update.. If that is possible. If this make sense ๐Ÿ™‚
          • fredo6F
            fredo6
            Yes, indeed. Rdaius and angle are related. My question is whether you know in your model what value of radius you would enter?
            panixiaP 1 Reply Last reply
            • panixiaP
              panixia @fredo6
              To be fair, I see quite a lot of real world use cases where it's easier to know which radius is needed, rather than the angle.
              Sounds like a reasonable feature request.
              • fredo6F
                fredo6
                This is a reasonable feature request for sure. I did not include it because personally, I did not see cases where I would have to specify the radius rather than the angle.
                Actually the angle is an absolute parameter, that will stay the same, even if the shape changes.
                In contrast, the radius depends on the total length of the shape along the bending direction. If you change the shape, the radius will change. Somehow, input of the radius is a one-time specification to compute the equivaleent angle for the given shape.
                • J
                  jonorman
                  Yes, In example: We are buliding a big tank, 30 meters in diameter. This is made of rolled plates. I don`t allways know the length of the plate, but i know the diameter of the tank, so it would be easy to just punch in that number.
                  Reply Quote -1
                  • fredo6F
                    fredo6
                    Ok. This is not complex to add in FredoBend, both for the Circular tool and the Dome tool.
                    However, there is question of the precedence of the angle versus the radius, since they are both related by a formula which also includes the length of the original shape along the bending direction.
                    1) Should the angle always prevail? that is, when you specify a radius, it calculates the angle and keep the angle as the main parameter. So, entering a radius is just a transient way to specify the angle.
                    2) or should the input mode be remembered? that is, if you specify a radius, FredoBend remembers that you specified a radius and will keep your radius value and adjust the angle dynamically, should the original shape change. Same if you specify an angle, it remembers that you specified than angle and will adjust the radius accordingly.
                    I also have to find a way to specify the radius in the VCB. Currently, a simple float value is for the angle. So, I'll probably set the convention for radius to be a flaot followed by a 'r' (ex: 3.5r, means 3.5 in current model unit), or a float with unit specification (ex: 3.5m or 3.5').
                    • panixiaP
                      panixia @fredo6
                      I guess option 2 is the correct one.
                      I guess r3,5 should be model uinits
                      And r3,5 plus units should set an arbitrary unit (different from the default model unit)
                      If you put the "r" BEFORE the number I guess that you can safely assume that it will be radius based.
                      If there's no "r" in front, then the number specify the angle.
                      If you put it after the number how do you specify the arbitrary unit?
                      In your example should be something like 3,5rcm (wich is weird compared to r3.5cm in my opinion).
                      • J
                        jonorman
                        Opjtion 2 sounds good.
                        • fredo6F
                          fredo6
                          For information, you CANNOT put 'r' in front of the number. If you type 'r' as first character, then Sketchup will switch to whatever command has a shortcut 'r'.
                          The distinction between radius, angle and number of segments is based on whether a letter follows the number:
                          • if no character or 'd', this is an angle
                          • if 's', this is a number of segments
                          • if 'r' this is a radius
                          • if something else that can be interpreted as a unit (', ", m, cm, mm, etc...), then it is also a radius with specified units
                          • otherwise, it is ignored
                          Note that in the case of the Dome tool, you can add a digit 1 or 2 after, to specify whether this relates to the first or second curve.
                          • 33s2 will set 33 segments for the second curve
                          • 45.3d2 will set the angle to 45.3 degrees for the second curve
                          • so, 35.6r2 will set the radius to 35.6 model unit for the second curve
                          • and 35.6m2 will set the radius to 35.6m for the second curve
                          To finish with the VCB convention, if you type 2 values that are of the same categories, they apply to the curve1 and then the curve2. For instance: '33.4 45.6' will set the angles to 33.4 deg. for curve1 and 45.6 deg. for curve 2.
                          • panixiaP
                            panixia @fredo6
                            Doh, that's right!
                            • J
                              jonorman
                              Another question on this matter. Are the Bending / rolling done on any K-value/factor rule ?? If so, would it be possible to have a box to edit that value ?? This matter to me in mine line of work. As mentioned, we roll plates, and in various thikness, so that would be a nice feature to have as well ๐Ÿ™‚
                              • fredo6F
                                fredo6
                                Can you tell me what is the K-value/factor again? I don't think FredoBend uses this concept. It is purely geometrical, not physical.
                                • J
                                  jonorman
                                  Here is a AI sumary of the meaning of K-factor when rolling plates (And for all those out there with a better answer, please dont hate, just add better answer/description to the conversation, thank you):
                                  When you bend or roll a metal plate, the material on the inside of the bend compresses, while the material on the outside stretches. Somewhere between these two surfaces lies a magical line that doesn't change length at all: the neutral axis.
                                  The K-factor is the ratio that determines exactly where this neutral axis sits, and it is absolutely critical for calculating how much a plate will "stretch" during the rolling or bending process.
                                  The K-factor is defined by a simple ratio: K=t/T (t over T, not divided.)
                                  • t = The distance from the inside surface of the bend to the neutral axis.
                                  • T= The total thickness of the plate.
                                  Because it's a ratio of the material's thickness, the K-factor is always a value between 0 and 1. In a perfect, theoretical world where materials don't stretch or compress differently, the neutral axis would be dead center ($K = 0.5$). In reality, because metal compresses less easily than it stretches, the neutral axis shifts toward the inside of the bend, meaning K-factors usually fall between 0.3 and 0.5.
                                  Why It Matters When Rolling Plates
                                  When you roll a flat plate into a cylinder or a curve, you need to know exactly how long the flat sheet needs to be before it hits the rollers. If you don't account for the K-factor, your final part will either be too big or too small.
                                  • Calculating Flat Length (Developments): Engineers use the K-factor to calculate the Bend Allowanceโ€”the actual length of the material along the neutral axis.
                                  -Precision Manufacturing: If you are rolling heavy plates for pressure vessels, pipes, or tanks, even a tiny error in the K-factor can result in a cylinder that doesn't close properly or violates strict structural tolerances.
                                  Typical K-Factor Values
                                  The exact K-factor changes depending on the material type, its hardness, the thickness of the plate, and the radius of the bend. However, here are some common industry starting points:
                                  -Soft Copper / Brass 0.35 โ€“ 0.40
                                  -Aluminum (Soft/Medium) 0.40 โ€“ 0.45
                                  -Medium Carbon Steel 0.40 โ€“ 0.45
                                  Maybe this is way of what you ment for FredoBend, but it sure would be nice to have. And the features you allready added, like editing the original plate, and then go back to rolled, is great.
                                  • fredo6F
                                    fredo6
                                    NEW RELEASE: FredoBend v1.5b - 23 Jul 26
                                    Requirements
                                    • LibFredo6: v15.9a or above
                                    FredoBend 1.5b is a maintenance release including:
                                    • Adjustment for shear normal
                                    • Future compatibility
                                    Home Page of FredoBend for information and Download.
                                    Main post of this FredoBend thread.
                                    • T
                                      TeKnoel
                                      Hi.
                                      Fantastic Plugin and a great addition to my work flow. It's really cool that there is a way to use it and preserve the quad layout for Sub D workflows. It works well when using the main path based bending but unfortunately the Circular and Dome tools don't seem to work as well. They unsoften the triangulated edge. May well be in development for a future release but I though I'd mention it in case you were not aware.
                                      • fredo6F
                                        fredo6
                                        It would help to see the model.
                                        Note that there are options to prevent auto-smooth
                                        • fredo6F
                                          fredo6
                                          NEW RELEASE: FredoBend v1.6a - 21 Oct 26
                                          Requirements
                                          • LibFredo6: v16.3a or above
                                          FredoBend 1.6a is a maintenance release including:
                                          • Compatibility SU2027
                                          • V
                                            Vets @fredo6
                                            @fredo6
                                            Hi brother I have almost all your plugin licences and I want Fredo bend too but now I am not able to pay outstanding of 30 in full can u please give me some consetion as my economic conditions are not good these days kindly review my request ๐Ÿ™ and reply me my email is
                                            [EMAIL REDACTED]
                                            V 1 Reply Last reply
                                            Reply Quote -1
                                            • 4 / 5
