[Plugin][$] FredoBend - v1.5b - 23 Jul 26
Hi. Would editing radius be a possibility as well as angle ??
@fredo6 Yes, it would be nice to either give angle value, or radius. Maybe following: If you change angel in the angle value, the radius automaticly update, and if you then if you change the radius value the angle value would update.. If that is possible. If this make sense
Yes, indeed. Rdaius and angle are related. My question is whether you know in your model what value of radius you would enter?
This is a reasonable feature request for sure. I did not include it because personally, I did not see cases where I would have to specify the radius rather than the angle.
Actually the angle is an absolute parameter, that will stay the same, even if the shape changes.
In contrast, the radius depends on the total length of the shape along the bending direction. If you change the shape, the radius will change. Somehow, input of the radius is a one-time specification to compute the equivaleent angle for the given shape.
Yes, In example: We are buliding a big tank, 30 meters in diameter. This is made of rolled plates. I don`t allways know the length of the plate, but i know the diameter of the tank, so it would be easy to just punch in that number.
Ok. This is not complex to add in FredoBend, both for the Circular tool and the Dome tool.
However, there is question of the precedence of the angle versus the radius, since they are both related by a formula which also includes the length of the original shape along the bending direction.
1) Should the angle always prevail? that is, when you specify a radius, it calculates the angle and keep the angle as the main parameter. So, entering a radius is just a transient way to specify the angle.
2) or should the input mode be remembered? that is, if you specify a radius, FredoBend remembers that you specified a radius and will keep your radius value and adjust the angle dynamically, should the original shape change. Same if you specify an angle, it remembers that you specified than angle and will adjust the radius accordingly.
I also have to find a way to specify the radius in the VCB. Currently, a simple float value is for the angle. So, I'll probably set the convention for radius to be a flaot followed by a 'r' (ex: 3.5r, means 3.5 in current model unit), or a float with unit specification (ex: 3.5m or 3.5').
I guess option 2 is the correct one.
I guess r3,5 should be model uinits
And r3,5 plus units should set an arbitrary unit (different from the default model unit)If you put the "r" BEFORE the number I guess that you can safely assume that it will be radius based.
If there's no "r" in front, then the number specify the angle.If you put it after the number how do you specify the arbitrary unit?
In your example should be something like 3,5rcm (wich is weird compared to r3.5cm in my opinion). -
Opjtion 2 sounds good.
For information, you CANNOT put 'r' in front of the number. If you type 'r' as first character, then Sketchup will switch to whatever command has a shortcut 'r'.
The distinction between radius, angle and number of segments is based on whether a letter follows the number:
- if no character or 'd', this is an angle
- if 's', this is a number of segments
- if 'r' this is a radius
- if something else that can be interpreted as a unit (', ", m, cm, mm, etc...), then it is also a radius with specified units
- otherwise, it is ignored
Note that in the case of the Dome tool, you can add a digit 1 or 2 after, to specify whether this relates to the first or second curve.
- 33s2 will set 33 segments for the second curve
- 45.3d2 will set the angle to 45.3 degrees for the second curve
- so, 35.6r2 will set the radius to 35.6 model unit for the second curve
- and 35.6m2 will set the radius to 35.6m for the second curve
To finish with the VCB convention, if you type 2 values that are of the same categories, they apply to the curve1 and then the curve2. For instance: '33.4 45.6' will set the angles to 33.4 deg. for curve1 and 45.6 deg. for curve 2.
Another question on this matter. Are the Bending / rolling done on any K-value/factor rule ?? If so, would it be possible to have a box to edit that value ?? This matter to me in mine line of work. As mentioned, we roll plates, and in various thikness, so that would be a nice feature to have as well
Can you tell me what is the K-value/factor again? I don't think FredoBend uses this concept. It is purely geometrical, not physical.
Here is a AI sumary of the meaning of K-factor when rolling plates (And for all those out there with a better answer, please dont hate, just add better answer/description to the conversation, thank you):
When you bend or roll a metal plate, the material on the inside of the bend compresses, while the material on the outside stretches. Somewhere between these two surfaces lies a magical line that doesn't change length at all: the neutral axis.
The K-factor is the ratio that determines exactly where this neutral axis sits, and it is absolutely critical for calculating how much a plate will "stretch" during the rolling or bending process.
The K-factor is defined by a simple ratio: K=t/T (t over T, not divided.)
- t = The distance from the inside surface of the bend to the neutral axis.
- T= The total thickness of the plate.
Because it's a ratio of the material's thickness, the K-factor is always a value between 0 and 1. In a perfect, theoretical world where materials don't stretch or compress differently, the neutral axis would be dead center ($K = 0.5$). In reality, because metal compresses less easily than it stretches, the neutral axis shifts toward the inside of the bend, meaning K-factors usually fall between 0.3 and 0.5.
Why It Matters When Rolling Plates
When you roll a flat plate into a cylinder or a curve, you need to know exactly how long the flat sheet needs to be before it hits the rollers. If you don't account for the K-factor, your final part will either be too big or too small.
- Calculating Flat Length (Developments): Engineers use the K-factor to calculate the Bend Allowance—the actual length of the material along the neutral axis.
-Precision Manufacturing: If you are rolling heavy plates for pressure vessels, pipes, or tanks, even a tiny error in the K-factor can result in a cylinder that doesn't close properly or violates strict structural tolerances.
Typical K-Factor Values
The exact K-factor changes depending on the material type, its hardness, the thickness of the plate, and the radius of the bend. However, here are some common industry starting points:
-Soft Copper / Brass 0.35 – 0.40
-Aluminum (Soft/Medium) 0.40 – 0.45
-Medium Carbon Steel 0.40 – 0.45Maybe this is way of what you ment for FredoBend, but it sure would be nice to have. And the features you allready added, like editing the original plate, and then go back to rolled, is great.
NEW RELEASE: FredoBend v1.5b - 23 Jul 26
Requirements
- LibFredo6: v15.9a or above
- Sketchup version: SU2017 and above
FredoBend 1.5b is a maintenance release including:
- Adjustment for shear normal
- Future compatibility
Home Page of FredoBend for information and Download.
