    Discussion - object is not a manifold solid !?
    6 Posts 4 Posters 511 Views 4 Watching
      bengali073 Newcomers
      Re: Slicer5 - Object is not manifold solid
      Hai Mr.DAVE
      Could you help my, i have some Problem, the object that i want to Slice can,tfailed.jpg
      after completely push and pull the surface by Fredoo, i cant to slice it
        Rich O Brien Moderator @bengali073
        @bengali073
        Do you have nested groups?
        Try Solid Inspector: https://sketchucation.com/pluginstore?pln=tt_solid_inspector2
        Or Fix It: https://sketchucation.com/pluginstore?pln=FixIt_101
        • alexpacio2013A Offline
          alexpacio2013
          Bool tools 2 also works on non-solid objects. I have not used the standard solid tools in sketchup for a long time, replacing them with bool Tools 2
            Dave R @alexpacio2013
            @alexpacio2013 said in Discussion - object is not a manifold solid !?:
            However it doesn't always yield the desired results when one of the objects isn't solid. Best to make sure the objects are clean and solid before running Bool Tools 2.
              alexpacio2013
              Surely cleaning objects to turn them into solids is the best solution, but in case the objects have a lot of bugs, it becomes exhausting to fix them. I guarantee you that Bool tools 2 works and works better than the standard tools even among solids
                You're preaching to the choir on that point. I don't use nor even recommend the native Solid Tools.
                I guess I have no problem, even for complex objects, with making them solids so I get predictable results when using Bool Tools 2 or Eneroth Solid Tools.
