    How can I move plugins installed with Sketchup Extension Warehouse to Extension Store?
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    10 Posts 4 Posters 827 Views 4 Watching
    • alexpacio2013A
      alexpacio2013
      Do I have to reinstall all the plugins with extension store? Do I have to reinstall the licenses or do they remain
      • Rich O BrienR Rich O Brien marked this topic as a question on
      • TIGT
        TIG Moderator @alexpacio2013
        @alexpacio2013
        If you have extensions that you installed from the Extension Warehouse and they are also available from our ExtensionStore, then you can simply install a version from our ExtensionStore.
        Later on if there's an update the ExtensionStore dialog will tell you and you can install it that way.
        The Extension Warehouse might also tell you when there's an update available from there - you can only prevent this by uninstalling it from the Extension Warehouse.
        Where licensing is involved you need to stick with the hosting platform that handles it...
          Rich O Brien Moderator @alexpacio2013
          @alexpacio2013
          You can't....though I'm not entirely sure what you are asking by moving?
          You can if you want. We have the Bundle install option that allows you to easily move devices or versions
          It basically records what you have installed using Sketchucation Tools from us to a device so you can just install that bundle to a new device or sketchup version easily
          It depends on whether you are moving devices. I don't know what you are doing because there's missing information.
          • alexpacio2013A
            alexpacio2013
            Basically I would like to manage the plugin from the Extension store in order to update the plugins more efficiently but I have never installed the plugins with the extense store and I wanted to know if there is a method to see the plugins installed on the extension store without having to install all the plugins again.
            Rich O BrienR TIGT 2 Replies Last reply
              @alexpacio2013 if there is a method to see the plugins installed on the extension store without having to install all the plugins again.
              I'd suggest just giving it a try. Its a lot easier
              We do put a little dot next to something you've installed as a reminder as you browse
              And under Bundles you'll see everything in a handy list
              I think the best approach is to just give it a try. Its free and personally I think its πŸ†’
              If you don't like just remove it
              • alexpacio2013A
                alexpacio2013
                I have never installed with extension store but my question is, what I have already installed with sketchup extension can I automatically transfer it to extension store installations? Do I have to reinstall all my plugins with extension store store?
                  @alexpacio2013
                  No
                  No
                  • TIGT
                    @alexpacio2013
                    To return to your original post...
                    The native Extension Warehouse and our ExtensionStore are different things.
                    Some authors use both platforms to host their extensions.
                    But others use one platform exclusively - like Fredo and myself use SCF.
                    So you cannot have all of the extensions you use under one platform.
                    Also licensing in dealt with in a different way on the two platforms, so if you have licensed extension you need to use the platform controlling its licensing.
                    Another point to note is that some developers use their own web-site and licensing system, so then there's an extra layer of complexity to consider...
                    alexpacio2013A 1 Reply Last reply
                    • alexpacio2013A
                      alexpacio2013 @TIG
                      @TIG Thanks I understand. But my question was another I wanted to know if some plugins that I have on extension warehouse are compatible with extension store I can transfer them, is there a procedure or do I have to reinstall them on extension store? Like, Fredo6, Thomthom, s4u, curic, .... ec
                      Dave RD TIGT 2 Replies Last reply
                        Dave R @alexpacio2013
                        @alexpacio2013 this has nothing to do with compatibility. The Sketchucation ExtensionStore only accesses those extensions available from Sketchucation. For extensions from the Extension Warehouse, install them fresh using the Extension Warehouse UI in SketchUp.
                        • TIGT
                          @alexpacio2013
                          • alexpacio2013A alexpacio2013 has marked this topic as solved on
