    Fredo Lord of Toolbars no longer working
    26 Posts 7 Posters 3.1k Views 7 Watching
    • K
      kylekin Newcomers
      Anyone else having this issue? Tools no longer activate when I click on them -- nor can I add to favorites toolbars.
      I have everything updated (Fredo extensions and sketchup). I'm on a Mac (for how much longer who knows...).
      L F 2 Replies Last reply
      • L
        lovellmarc @kylekin
        @kylekin Im having this issues
        • F
          FireDean @kylekin
          @kylekin Im having same issue....Useing a MacBook Pro M3. Fredo is listed in my Extension Manager as signed an licenced but the Fredo menu bar is no where to be seen
          fredo6F 1 Reply Last reply
          • fredo6F
            fredo6 @FireDean
            @FireDean
            Could you indicate which version of Sketchup you run.
            Could you do the following:
            • open the Ruby console
            • Close Sketchup
            • Relaunch Sketchup
            • The Ruby console should automatically open and possibly shows errors in the startup sequence, including for LOTT.
            Fredo
            K 1 Reply Last reply
            • K
              kylekin Newcomers @fredo6
              @fredo6 All appears fixed with the Sketchup 2024 update.
              • cmeedC
                cmeed
                HI Fredo
                I am also experiencing issues - I've upgraded to 2024 and the vignette bar isnt correct, only a small portion can be seen.
                The icons you see can be used as usual, anything to the right gone
                made the vignette smaller, by opening the 2024-04-06_07-50-22.jpg and using the menu to alter the icon vignette bar - which results in the same but smaller
                The ruby console is clear - apart from
                "English"
                true
                "Can not load Curic Helpper!"
                Any thoughts
                Cheers
                Chris
                supplementary:
                As the
                button is working I tried opening importing my .lott from SU23
                then noticed that theres no synchronize buttons visible (the window is open to the maximum)
                in SU23 this should look like this ?
                • fredo6F
                  fredo6 @cmeed
                  @cmeed
                  There are a few issues with dialogs in SU2024.
                  When the dialog appears, can you slightly resize it. It should show all buttons.
                  cmeedC 1 Reply Last reply
                  • cmeedC
                    cmeed @fredo6
                    @fredo6
                    • fredo6F
                      fredo6 @cmeed
                      @cmeed
                      Obviously there is a general problems with dialogs in your environment. I cannot reproduce it in mine.
                      Just to be sure, did you upgrade to LOTT v2.7a?
                      If so, maybe a clean reinstall would help. In the Plugins directory, erase the folders Fredo6_!LIbFredo6 and Fredo6_LordOfTheToolbars and then reinstall from Sketchucation.
                      cmeedC 2 Replies Last reply
                      • cmeedC
                        cmeed @fredo6
                        LOTT 2.7a? or 2.7b - just checking
                        b is on the sketcucation pluginstore
                        • cmeedC
                          cmeed @fredo6
                          @fredo6
                          I have done a clean install of your plugins - nothing changed
                          then... did a clean install (as administrator) of sketchup 2024
                          deleted the contents of the plugins folder
                          downloaded sketchucation Plugin Store
                          then
                          fredoLib
                          and
                          lord of the toolbars
                          fredo6F 2 Replies Last reply
                          • fredo6F
                            fredo6 @cmeed
                            @cmeed
                            I don't have an explanation to the cropping of dialogs. I guess you are on Windows 11, but that should not make a difference.
                            Could you open another dialog, ay Check Plugins for Update in te menu LibFredo6 and see if you see the buttons.
                            Also, do you have several monitors, and is Sketchup on the main monitor ?
                            • fredo6F
                              fredo6 @cmeed
                              @cmeed
                              Would you mind to execute the menu Window > LibFredo6 Settings... > Fredo6 Plugin information for Sketchucation Support.
                              There seems to be an issue at load of dialogs.
                              B cmeedC 2 Replies Last reply
                              • B
                                Bradiks Newcomers @fredo6
                                @fredo6 Running MacBook Pro M2 Max OSX 14.4.1, Sketchup Pro 2024, LibFredo6 14.3b, LTB 2.7b
                                Can not get icons to "drag and drop" to Palettes. Check marks by all my extensions but still no luck.
                                • fredo6F
                                  fredo6 @Bradiks
                                  @Bradiks
                                  Could you describe more precisely what you see not working.
                                  When you drag a command icon, do you see it moving with the mouse?
                                  Or does it fail to insert?
                                  • T
                                    TECHDAVE02
                                    • cmeedC
                                      cmeed @fredo6
                                      @fredo6 apologies for leaving you hanging - I've been away
                                      heres the copy and paste of the ruby console after
                                      Fredo6 Plugins Information on 2024-04-17 10:35:20 +0100
                                      • Platform: x64-mswin64_140 - Ruby: 3.2.2
                                      • Sketchup: 24.0.484
                                      • LibFredo6: v14.3b
                                      • LibFredo6 Binary loaded
                                      • Sketchucation ExtensionStore: 4.4.0
                                      • SCFLicense: v6.4a - 74
                                      • Fredo6 Plugins
                                        LordOfTheToolbars v2.7b
                                      • SCFLicense directory present
                                        Signature File: 2022-04-26 16:11:44 +0100
                                        ClothWorks: 2024-01-08 21:28:53 +0000
                                        Curviloft: 2022-06-15 11:06:32 +0100
                                        Curvizard: 2022-11-26 09:35:34 +0000
                                        FredoCorner: 2023-01-10 14:41:27 +0000
                                        FredoPortrait: 2022-10-24 11:05:49 +0100
                                        FredoScale: 2023-05-19 10:17:07 +0100
                                        FredoSpline: 2022-11-15 18:43:07 +0000
                                        JointPushPull: 2023-04-26 15:43:32 +0100
                                        RoundCorner: 2022-05-17 16:14:20 +0100
                                        ToolsOnSurface: 2022-11-24 18:36:54 +0000
                                      • cmeedC
                                        cmeed @fredo6
                                        looks like the 'check for Fredo6 ...' window is also not right.
                                        yes I have a multi monitor setup
                                        Laptop and a Monitor - SU on the main monitor
                                        • fredo6F
                                          fredo6 @cmeed
                                          @cmeed
                                          Your installation looks correct, withe the latest version.
                                          For whatever reason, there seems to be an issue with the load sequence of dialogs. Some events seem not to be received, hence the partial display of dialogs.
                                          Could you open the Ruby console and copy/paste the following command (and then press Enter).
                                          UI.openURL File.join(LibFredo6.tmpdir, 'Binaries', 'SU24').
                                          This will open the folder where the active binary of LibFredo6, with the name: bin_body_Lib6G6.so. Can you tell me the date of the file.
                                          Then, close Sketchup, and try to delete this file.
                                          Then restart Sketchup (the file will be recreated).
                                          • cmeedC
                                            cmeed @fredo6
                                            @fredo6 said in Fredo Lord of Toolbars no longer working:
                                            Hi Fredo,
                                            Not sure this is what you were expecting ...
                                            Error: #<SyntaxError:"(eval):1: syntax error, unexpected end-of-input\n...o6.tmpdir, 'Binaries', 'SU24').\n... ^\n">
                                            SketchUp:in `eval'
                                            => nil
                                            • 1 / 2
