    Fredo Lord of Toolbars no longer working
    26 Posts 7 Posters 2.5k Views 7 Watching
    • fredo6F
      fredo6 @cmeed
      @cmeed
      Obviously there is a general problems with dialogs in your environment. I cannot reproduce it in mine.
      Just to be sure, did you upgrade to LOTT v2.7a?
      If so, maybe a clean reinstall would help. In the Plugins directory, erase the folders Fredo6_!LIbFredo6 and Fredo6_LordOfTheToolbars and then reinstall from Sketchucation.
      cmeedC 2 Replies Last reply
      • cmeedC
        cmeed @fredo6
        LOTT 2.7a? or 2.7b - just checking
        b is on the sketcucation pluginstore
        • cmeedC
          cmeed @fredo6
          @fredo6
          I have done a clean install of your plugins - nothing changed
          then... did a clean install (as administrator) of sketchup 2024
          deleted the contents of the plugins folder
          downloaded sketchucation Plugin Store
          then
          fredoLib
          and
          lord of the toolbars
          fredo6F 2 Replies Last reply
          • fredo6F
            fredo6 @cmeed
            @cmeed
            I don't have an explanation to the cropping of dialogs. I guess you are on Windows 11, but that should not make a difference.
            Could you open another dialog, ay Check Plugins for Update in te menu LibFredo6 and see if you see the buttons.
            Also, do you have several monitors, and is Sketchup on the main monitor ?
            cmeedC 1 Reply Last reply
            • fredo6F
              fredo6 @cmeed
              @cmeed
              Would you mind to execute the menu Window > LibFredo6 Settings... > Fredo6 Plugin information for Sketchucation Support.
              There seems to be an issue at load of dialogs.
              B cmeedC 2 Replies Last reply
              • B
                Bradiks Newcomers @fredo6
                @fredo6 Running MacBook Pro M2 Max OSX 14.4.1, Sketchup Pro 2024, LibFredo6 14.3b, LTB 2.7b
                Can not get icons to "drag and drop" to Palettes. Check marks by all my extensions but still no luck.
                fredo6F 1 Reply Last reply
                • fredo6F
                  fredo6 @Bradiks
                  @Bradiks
                  Could you describe more precisely what you see not working.
                  When you drag a command icon, do you see it moving with the mouse?
                  Or does it fail to insert?
                  • T
                    TECHDAVE02
                    • cmeedC
                      cmeed @fredo6
                      @fredo6 apologies for leaving you hanging - I've been away
                      heres the copy and paste of the ruby console after
                      Fredo6 Plugins Information on 2024-04-17 10:35:20 +0100
                      • Sketchup: 24.0.484
                      • LibFredo6: v14.3b
                      • LibFredo6 Binary loaded
                      • Sketchucation ExtensionStore: 4.4.0
                      • SCFLicense: v6.4a - 74
                      • Fredo6 Plugins
                        LordOfTheToolbars v2.7b
                        Signature File: 2022-04-26 16:11:44 +0100
                        ClothWorks: 2024-01-08 21:28:53 +0000
                        Curviloft: 2022-06-15 11:06:32 +0100
                        Curvizard: 2022-11-26 09:35:34 +0000
                        FredoCorner: 2023-01-10 14:41:27 +0000
                        FredoPortrait: 2022-10-24 11:05:49 +0100
                        FredoScale: 2023-05-19 10:17:07 +0100
                        FredoSpline: 2022-11-15 18:43:07 +0000
                        JointPushPull: 2023-04-26 15:43:32 +0100
                        RoundCorner: 2022-05-17 16:14:20 +0100
                        ToolsOnSurface: 2022-11-24 18:36:54 +0000
                      • cmeedC
                        cmeed @fredo6
                        looks like the 'check for Fredo6 ...' window is also not right.
                        yes I have a multi monitor setup
                        Laptop and a Monitor - SU on the main monitor
                        • fredo6F
                          fredo6 @cmeed
                          @cmeed
                          Your installation looks correct, withe the latest version.
                          For whatever reason, there seems to be an issue with the load sequence of dialogs. Some events seem not to be received, hence the partial display of dialogs.
                          Could you open the Ruby console and copy/paste the following command (and then press Enter).
                          UI.openURL File.join(LibFredo6.tmpdir, 'Binaries', 'SU24').
                          This will open the folder where the active binary of LibFredo6, with the name: bin_body_Lib6G6.so. Can you tell me the date of the file.
                          Then, close Sketchup, and try to delete this file.
                          Then restart Sketchup (the file will be recreated).
                          • cmeedC
                            cmeed @fredo6
                            @fredo6 said in Fredo Lord of Toolbars no longer working:
                            Hi Fredo,
                            Not sure this is what you were expecting ...
                            Error: #<SyntaxError:"(eval):1: syntax error, unexpected end-of-input\n...o6.tmpdir, 'Binaries', 'SU24').\n... ^\n">
                            SketchUp:in `eval'
                            => nil
                            • fredo6F
                              fredo6 @cmeed
                              @cmeed
                              Don’t include the final dot
                              • T
                                TECHDAVE02
                                NO Luck still same issues 😞
                                • cmeedC
                                  cmeed @fredo6
                                  @fredo6
                                  excluded the ' . ' and as expected file exploer showed this
                                  • fredo6F
                                    fredo6 @cmeed
                                    @cmeed
                                    The binary is OK.
                                    Did you try to check the Text scaling in Windows (see this post)?
                                    • T
                                      TECHDAVE02
                                      text scale no luck
                                      • cmeedC
                                        cmeed @fredo6
                                        @fredo6
                                        Yes! this has done it for me!! - Thank you so much for helping me sort this out.... I enlarged my computer fontsize recently, also, I increased the text size on my phone.... its a sign of getting older!! booo!
                                        BUTI refuse to say ahhh when i sit down...
                                        Thank you again - this really is a productive tool for me. Cant thank enough!
                                        @TECHDAVE02 - sorry this hasn't solved your issue!
