    Fredo Lord of Toolbars no longer working
    26 Posts 7 Posters 2.1k Views 7 Watching
    • cmeedC Offline
      cmeed @fredo6
      @fredo6
      fredo6F 1 Reply Last reply Reply Quote 0
      • fredo6F Offline
        fredo6 @cmeed
        @cmeed
        Obviously there is a general problems with dialogs in your environment. I cannot reproduce it in mine.
        Just to be sure, did you upgrade to LOTT v2.7a?
        If so, maybe a clean reinstall would help. In the Plugins directory, erase the folders Fredo6_!LIbFredo6 and Fredo6_LordOfTheToolbars and then reinstall from Sketchucation.
        cmeedC 2 Replies Last reply Reply Quote 0
        • cmeedC Offline
          cmeed @fredo6
          LOTT 2.7a? or 2.7b - just checking
          b is on the sketcucation pluginstore
          • cmeedC Offline
            cmeed @fredo6
            @fredo6
            I have done a clean install of your plugins - nothing changed
            then... did a clean install (as administrator) of sketchup 2024
            deleted the contents of the plugins folder
            downloaded sketchucation Plugin Store
            then
            fredoLib
            and
            lord of the toolbars
            fredo6F 2 Replies Last reply Reply Quote 0
            • fredo6F Offline
              fredo6 @cmeed
              @cmeed
              I don't have an explanation to the cropping of dialogs. I guess you are on Windows 11, but that should not make a difference.
              Could you open another dialog, ay Check Plugins for Update in te menu LibFredo6 and see if you see the buttons.
              Also, do you have several monitors, and is Sketchup on the main monitor ?
              cmeedC 1 Reply Last reply Reply Quote 0
              • fredo6F Offline
                fredo6 @cmeed
                @cmeed
                Would you mind to execute the menu Window > LibFredo6 Settings... > Fredo6 Plugin information for Sketchucation Support.
                There seems to be an issue at load of dialogs.
                B cmeedC 2 Replies Last reply Reply Quote 0
                  Bradiks Newcomers @fredo6
                  @fredo6 Running MacBook Pro M2 Max OSX 14.4.1, Sketchup Pro 2024, LibFredo6 14.3b, LTB 2.7b
                  Can not get icons to "drag and drop" to Palettes. Check marks by all my extensions but still no luck.
                  • fredo6F Offline
                    fredo6 @Bradiks
                    @Bradiks
                    Could you describe more precisely what you see not working.
                    When you drag a command icon, do you see it moving with the mouse?
                    Or does it fail to insert?
                      TECHDAVE02
                      • cmeedC Offline
                        cmeed @fredo6
                        @fredo6 apologies for leaving you hanging - I've been away
                        heres the copy and paste of the ruby console after
                        Fredo6 Plugins Information on 2024-04-17 10:35:20 +0100
                        • Sketchup: 24.0.484
                        • LibFredo6: v14.3b
                        • LibFredo6 Binary loaded
                        • Sketchucation ExtensionStore: 4.4.0
                        • SCFLicense: v6.4a - 74
                        • Fredo6 Plugins
                          LordOfTheToolbars v2.7b
                          Signature File: 2022-04-26 16:11:44 +0100
                          ClothWorks: 2024-01-08 21:28:53 +0000
                          Curviloft: 2022-06-15 11:06:32 +0100
                          Curvizard: 2022-11-26 09:35:34 +0000
                          FredoCorner: 2023-01-10 14:41:27 +0000
                          FredoPortrait: 2022-10-24 11:05:49 +0100
                          FredoScale: 2023-05-19 10:17:07 +0100
                          FredoSpline: 2022-11-15 18:43:07 +0000
                          JointPushPull: 2023-04-26 15:43:32 +0100
                          RoundCorner: 2022-05-17 16:14:20 +0100
                          ToolsOnSurface: 2022-11-24 18:36:54 +0000
                        • cmeedC Offline
                          cmeed @fredo6
                          looks like the 'check for Fredo6 ...' window is also not right.
                          yes I have a multi monitor setup
                          Laptop and a Monitor - SU on the main monitor
                          • fredo6F Offline
                            fredo6 @cmeed
                            @cmeed
                            Your installation looks correct, withe the latest version.
                            For whatever reason, there seems to be an issue with the load sequence of dialogs. Some events seem not to be received, hence the partial display of dialogs.
                            Could you open the Ruby console and copy/paste the following command (and then press Enter).
                            UI.openURL File.join(LibFredo6.tmpdir, 'Binaries', 'SU24').
                            This will open the folder where the active binary of LibFredo6, with the name: bin_body_Lib6G6.so. Can you tell me the date of the file.
                            Then, close Sketchup, and try to delete this file.
                            Then restart Sketchup (the file will be recreated).
                            • cmeedC Offline
                              cmeed @fredo6
                              @fredo6 said in Fredo Lord of Toolbars no longer working:
                              Hi Fredo,
                              Not sure this is what you were expecting ...
                              Error: #<SyntaxError:"(eval):1: syntax error, unexpected end-of-input\n...o6.tmpdir, 'Binaries', 'SU24').\n... ^\n">
                              SketchUp:in `eval'
                              => nil
                              • fredo6F Offline
                                fredo6 @cmeed
                                @cmeed
                                Don’t include the final dot
                                  TECHDAVE02
                                  NO Luck still same issues 😞
                                  • cmeedC Offline
                                    cmeed @fredo6
                                    @fredo6
                                    excluded the ' . ' and as expected file exploer showed this
                                    • fredo6F Offline
                                      fredo6 @cmeed
                                      @cmeed
                                      The binary is OK.
                                      Did you try to check the Text scaling in Windows (see this post)?
                                        TECHDAVE02
                                        text scale no luck
                                        • cmeedC Offline
                                          cmeed @fredo6
                                          @fredo6
                                          Yes! this has done it for me!! - Thank you so much for helping me sort this out.... I enlarged my computer fontsize recently, also, I increased the text size on my phone.... its a sign of getting older!! booo!
                                          BUTI refuse to say ahhh when i sit down...
                                          Thank you again - this really is a productive tool for me. Cant thank enough!
                                          @TECHDAVE02 - sorry this hasn't solved your issue!
