    Fredo Lord of Toolbars no longer working
    26 Posts 7 Posters 1.5k Views 7 Watching
    • fredo6F Offline
      fredo6 @cmeed
      @cmeed
      There are a few issues with dialogs in SU2024.
      When the dialog appears, can you slightly resize it. It should show all buttons.
      cmeedC 1 Reply Last reply Reply Quote 0
      • cmeedC Offline
        cmeed @fredo6
        @fredo6
        fredo6F 1 Reply Last reply Reply Quote 0
        • fredo6F Offline
          fredo6 @cmeed
          @cmeed
          Obviously there is a general problems with dialogs in your environment. I cannot reproduce it in mine.
          Just to be sure, did you upgrade to LOTT v2.7a?
          If so, maybe a clean reinstall would help. In the Plugins directory, erase the folders Fredo6_!LIbFredo6 and Fredo6_LordOfTheToolbars and then reinstall from Sketchucation.
          cmeedC 2 Replies Last reply Reply Quote 0
          • cmeedC Offline
            cmeed @fredo6
            LOTT 2.7a? or 2.7b - just checking
            b is on the sketcucation pluginstore
            • cmeedC Offline
              cmeed @fredo6
              @fredo6
              I have done a clean install of your plugins - nothing changed
              then... did a clean install (as administrator) of sketchup 2024
              deleted the contents of the plugins folder
              downloaded sketchucation Plugin Store
              then
              fredoLib
              and
              lord of the toolbars
              fredo6F 2 Replies Last reply Reply Quote 0
              • fredo6F Offline
                fredo6 @cmeed
                @cmeed
                I don't have an explanation to the cropping of dialogs. I guess you are on Windows 11, but that should not make a difference.
                Could you open another dialog, ay Check Plugins for Update in te menu LibFredo6 and see if you see the buttons.
                Also, do you have several monitors, and is Sketchup on the main monitor ?
                • fredo6F Offline
                  fredo6 @cmeed
                  @cmeed
                  Would you mind to execute the menu Window > LibFredo6 Settings... > Fredo6 Plugin information for Sketchucation Support.
                  There seems to be an issue at load of dialogs.
                  B cmeedC 2 Replies Last reply Reply Quote 0
                    Bradiks Newcomers @fredo6
                    @fredo6 Running MacBook Pro M2 Max OSX 14.4.1, Sketchup Pro 2024, LibFredo6 14.3b, LTB 2.7b
                    Can not get icons to "drag and drop" to Palettes. Check marks by all my extensions but still no luck.
                    • fredo6F Offline
                      fredo6 @Bradiks
                      @Bradiks
                      Could you describe more precisely what you see not working.
                      When you drag a command icon, do you see it moving with the mouse?
                      Or does it fail to insert?
                        TECHDAVE02
                        • cmeedC Offline
                          cmeed @fredo6
                          @fredo6 apologies for leaving you hanging - I've been away
                          heres the copy and paste of the ruby console after
                          Fredo6 Plugins Information on 2024-04-17 10:35:20 +0100
                          • Sketchup: 24.0.484
                          • LibFredo6: v14.3b
                          • LibFredo6 Binary loaded
                          • Sketchucation ExtensionStore: 4.4.0
                          • SCFLicense: v6.4a - 74
                          • Fredo6 Plugins
                            LordOfTheToolbars v2.7b
                            Signature File: 2022-04-26 16:11:44 +0100
                            ClothWorks: 2024-01-08 21:28:53 +0000
                            Curviloft: 2022-06-15 11:06:32 +0100
                            Curvizard: 2022-11-26 09:35:34 +0000
                            FredoCorner: 2023-01-10 14:41:27 +0000
                            FredoPortrait: 2022-10-24 11:05:49 +0100
                            FredoScale: 2023-05-19 10:17:07 +0100
                            FredoSpline: 2022-11-15 18:43:07 +0000
                            JointPushPull: 2023-04-26 15:43:32 +0100
                            RoundCorner: 2022-05-17 16:14:20 +0100
                            ToolsOnSurface: 2022-11-24 18:36:54 +0000
                          • cmeedC Offline
                            cmeed @fredo6
                            looks like the 'check for Fredo6 ...' window is also not right.
                            yes I have a multi monitor setup
                            Laptop and a Monitor - SU on the main monitor
                            • fredo6F Offline
                              fredo6 @cmeed
                              @cmeed
                              Your installation looks correct, withe the latest version.
                              For whatever reason, there seems to be an issue with the load sequence of dialogs. Some events seem not to be received, hence the partial display of dialogs.
                              Could you open the Ruby console and copy/paste the following command (and then press Enter).
                              UI.openURL File.join(LibFredo6.tmpdir, 'Binaries', 'SU24').
                              This will open the folder where the active binary of LibFredo6, with the name: bin_body_Lib6G6.so. Can you tell me the date of the file.
                              Then, close Sketchup, and try to delete this file.
                              Then restart Sketchup (the file will be recreated).
                              • cmeedC Offline
                                cmeed @fredo6
                                @fredo6 said in Fredo Lord of Toolbars no longer working:
                                Hi Fredo,
                                Not sure this is what you were expecting ...
                                Error: #<SyntaxError:"(eval):1: syntax error, unexpected end-of-input\n...o6.tmpdir, 'Binaries', 'SU24').\n... ^\n">
                                SketchUp:in `eval'
                                => nil
                                • fredo6F Offline
                                  fredo6 @cmeed
                                  @cmeed
                                  Don’t include the final dot
                                    TECHDAVE02
                                    NO Luck still same issues 😞
                                    • cmeedC Offline
                                      cmeed @fredo6
                                      @fredo6
                                      excluded the ' . ' and as expected file exploer showed this
                                      • fredo6F Offline
                                        fredo6 @cmeed
                                        @cmeed
                                        The binary is OK.
                                        Did you try to check the Text scaling in Windows (see this post)?
                                          TECHDAVE02
                                          text scale no luck
                                          • cmeedC Offline
                                            cmeed @fredo6
                                            @fredo6
                                            Yes! this has done it for me!! - Thank you so much for helping me sort this out.... I enlarged my computer fontsize recently, also, I increased the text size on my phone.... its a sign of getting older!! booo!
                                            BUTI refuse to say ahhh when i sit down...
                                            Thank you again - this really is a productive tool for me. Cant thank enough!
                                            @TECHDAVE02 - sorry this hasn't solved your issue!
