    Fredo Lord of Toolbars no longer working
    26 Posts 7 Posters 2.3k Views 7 Watching
      kylekin Newcomers @fredo6
      @fredo6 All appears fixed with the Sketchup 2024 update.
      • cmeedC Offline
        cmeed
        HI Fredo
        I am also experiencing issues - I've upgraded to 2024 and the vignette bar isnt correct, only a small portion can be seen.
        The icons you see can be used as usual, anything to the right gone
        made the vignette smaller, by opening the 2024-04-06_07-50-22.jpg and using the menu to alter the icon vignette bar - which results in the same but smaller
        The ruby console is clear - apart from
        "English"
        true
        "Can not load Curic Helpper!"
        Any thoughts
        Cheers
        supplementary:
        As the
        button is working I tried opening importing my .lott from SU23
        then noticed that theres no synchronize buttons visible (the window is open to the maximum)
        in SU23 this should look like this ?
        fredo6F 1 Reply Last reply Reply Quote 0
        • fredo6F Offline
          fredo6 @cmeed
          @cmeed
          There are a few issues with dialogs in SU2024.
          When the dialog appears, can you slightly resize it. It should show all buttons.
          cmeedC 1 Reply Last reply Reply Quote 0
          • cmeedC Offline
            cmeed @fredo6
            @fredo6
            • fredo6F Offline
              fredo6 @cmeed
              @cmeed
              Obviously there is a general problems with dialogs in your environment. I cannot reproduce it in mine.
              Just to be sure, did you upgrade to LOTT v2.7a?
              If so, maybe a clean reinstall would help. In the Plugins directory, erase the folders Fredo6_!LIbFredo6 and Fredo6_LordOfTheToolbars and then reinstall from Sketchucation.
              cmeedC 2 Replies Last reply Reply Quote 0
              • cmeedC Offline
                cmeed @fredo6
                LOTT 2.7a? or 2.7b - just checking
                b is on the sketcucation pluginstore
                • cmeedC Offline
                  cmeed @fredo6
                  @fredo6
                  I have done a clean install of your plugins - nothing changed
                  then... did a clean install (as administrator) of sketchup 2024
                  deleted the contents of the plugins folder
                  downloaded sketchucation Plugin Store
                  then
                  fredoLib
                  and
                  lord of the toolbars
                  fredo6F 2 Replies Last reply Reply Quote 0
                  • fredo6F Offline
                    fredo6 @cmeed
                    @cmeed
                    I don't have an explanation to the cropping of dialogs. I guess you are on Windows 11, but that should not make a difference.
                    Could you open another dialog, ay Check Plugins for Update in te menu LibFredo6 and see if you see the buttons.
                    Also, do you have several monitors, and is Sketchup on the main monitor ?
                    • fredo6F Offline
                      fredo6 @cmeed
                      @cmeed
                      Would you mind to execute the menu Window > LibFredo6 Settings... > Fredo6 Plugin information for Sketchucation Support.
                      There seems to be an issue at load of dialogs.
                      B cmeedC 2 Replies Last reply Reply Quote 0
                        Bradiks Newcomers @fredo6
                        @fredo6 Running MacBook Pro M2 Max OSX 14.4.1, Sketchup Pro 2024, LibFredo6 14.3b, LTB 2.7b
                        Can not get icons to "drag and drop" to Palettes. Check marks by all my extensions but still no luck.
                        • fredo6F Offline
                          fredo6 @Bradiks
                          @Bradiks
                          Could you describe more precisely what you see not working.
                          When you drag a command icon, do you see it moving with the mouse?
                          Or does it fail to insert?
                            TECHDAVE02
                            • cmeedC Offline
                              cmeed @fredo6
                              @fredo6 apologies for leaving you hanging - I've been away
                              heres the copy and paste of the ruby console after
                              Fredo6 Plugins Information on 2024-04-17 10:35:20 +0100
                              • Sketchup: 24.0.484
                              • LibFredo6: v14.3b
                              • LibFredo6 Binary loaded
                              • Sketchucation ExtensionStore: 4.4.0
                              • SCFLicense: v6.4a - 74
                              • Fredo6 Plugins
                                LordOfTheToolbars v2.7b
                                Signature File: 2022-04-26 16:11:44 +0100
                                ClothWorks: 2024-01-08 21:28:53 +0000
                                Curviloft: 2022-06-15 11:06:32 +0100
                                Curvizard: 2022-11-26 09:35:34 +0000
                                FredoCorner: 2023-01-10 14:41:27 +0000
                                FredoPortrait: 2022-10-24 11:05:49 +0100
                                FredoScale: 2023-05-19 10:17:07 +0100
                                FredoSpline: 2022-11-15 18:43:07 +0000
                                JointPushPull: 2023-04-26 15:43:32 +0100
                                RoundCorner: 2022-05-17 16:14:20 +0100
                                ToolsOnSurface: 2022-11-24 18:36:54 +0000
                              • cmeedC Offline
                                cmeed @fredo6
                                looks like the 'check for Fredo6 ...' window is also not right.
                                yes I have a multi monitor setup
                                Laptop and a Monitor - SU on the main monitor
                                • fredo6F Offline
                                  fredo6 @cmeed
                                  @cmeed
                                  Your installation looks correct, withe the latest version.
                                  For whatever reason, there seems to be an issue with the load sequence of dialogs. Some events seem not to be received, hence the partial display of dialogs.
                                  Could you open the Ruby console and copy/paste the following command (and then press Enter).
                                  UI.openURL File.join(LibFredo6.tmpdir, 'Binaries', 'SU24').
                                  This will open the folder where the active binary of LibFredo6, with the name: bin_body_Lib6G6.so. Can you tell me the date of the file.
                                  Then, close Sketchup, and try to delete this file.
                                  Then restart Sketchup (the file will be recreated).
                                  • cmeedC Offline
                                    cmeed @fredo6
                                    @fredo6 said in Fredo Lord of Toolbars no longer working:
                                    Hi Fredo,
                                    Not sure this is what you were expecting ...
                                    Error: #<SyntaxError:"(eval):1: syntax error, unexpected end-of-input\n...o6.tmpdir, 'Binaries', 'SU24').\n... ^\n">
                                    SketchUp:in `eval'
                                    => nil
                                    • fredo6F Offline
                                      fredo6 @cmeed
                                      @cmeed
                                      Don’t include the final dot
                                        TECHDAVE02
                                        NO Luck still same issues 😞
                                        • cmeedC Offline
                                          cmeed @fredo6
                                          @fredo6
                                          excluded the ' . ' and as expected file exploer showed this
                                          • fredo6F Offline
                                            fredo6 @cmeed
                                            @cmeed
                                            The binary is OK.
                                            Did you try to check the Text scaling in Windows (see this post)?
