    Rayscaper New Releases
    rayscaperrender
    438 Posts 11 Posters 61.8k Views 12 Watching
      Alattab @Krass
      @Krass thank you , i will try this slot , but there is an However, there is a difference between specular and specular tint. For clear water that has a specular, it is best to use metallic with the transparency.
      • KrassK Offline
        Krass
        Hi, would it be possible to have the total render time remain displayed in the dedicated window after the render is complete? Of course, I've noted the estimated time that appears during the animation render, but the final time disappears once the job is finished...
        Krass
        Mike AmosM P 2 Replies Last reply Reply Quote 0
          Mike Amos @Krass
          @Krass
          Not here mate. The render time is a constant.![Render Time Persistent.
          • KrassK Offline
            Krass
            Hi, I don't quite understand, do you mean the total rendering time is displayed at the bottom here? Also for the animation?
            Krass
              Pardon me, I missed the 'animation' part of your post, just wondering if it was a new behaviour from the app.
              • P Offline
                pixelcruncher Extension Creator @Alattab
                @Alattab said in Rayscaper New Releases:
                Just a suggestion: all PBR parameters should be available, in addition to an AO parameter that allows the user to add all PBR maps. Also, the ability to add FORE GROUND AND BACK GROUND should be added instead of using the environment image, and the ability to resize the environment image should also be included.
                Which application is this?
                AO parameter is on the list, but I haven't gotten around to it yet.
                By background, you mean adding an image to the backplate, for example for compositing? And would you then save this image as part of the render, or not?
                What is foreground? Do you have an example from other render software?
                The ability to resize the environment image should also be included.
                I'm not sure what that means. Do you mean a smaller / bigger resolution, or something else? The environment is wrapped as a "sphere" around your scene, so resizing will only impact the level of detail.
                Thanks for the feedback!
                Regards,
                Thomas
                A 1 Reply Last reply Reply Quote 0
                • P Offline
                  @Krass
                  So you mean keeping this window open until you explicitly close it after rendering?
                    Alattab
                    I'm still learning, and I hope the program's creator will allow me to provide feedback and suggest improvements. I'm a beginner with SketchUp and have tried many rendering programs that work independently, like Stanalone. I think it's great that it supports Intel OpenImage Denoiser. I'd like contrast control added to the post-processing section, and full PBR properties added, along with additional materials like transparent liquids, bubbled, fizz, and airborne water.
                      Alattab @pixelcruncher
                      @pixelcruncher Back palette (background) and front plate (foreground), like a keyshot render. If you choose a transparent background, you can add other images as a background or in front image as clipart in front of rendered image , some thing like whate happen in sketchup style editting
                      • KrassK Offline
                        Krass
                        Hi, why dont you use sky alpha mask with a photo editor ?
                        Krass
                        • KrassK Offline
                          Krass
                          About hdri scale I think Alattab means a physical dôme, like infinite dôme in vray, that can be stretched and scaled. This is very usefull. It is an hemisphere
                          Krass
                            Alattab
                            To make the program fully functional without relying on external applications, background and overlay options can be added to this list.
                              Alattab @Krass
                              @Krass ، as example simlab composser render engain can scale dome
                                Alattab
                                It is good thing to copy light properties to each each other
                                P 1 Reply Last reply Reply Quote 1
                                • P Offline
                                  @Alattab For someone still being in the learning phase, I'm already seeing some pretty impressive results 🙂
                                  And don't shy away from the feedback, love it! I take all the feedback seriously and try to add those as new features as I go.
                                  Noted.
                                  A new water material is coming soon. And I will iterate on that to give more options.
                                  • P Offline
                                    @Alattab Okay, that makes more sense. You want a backplate image to compose on? And the front would be to for example put your own logo and watermark on top of it?
                                      @pixelcruncher Actually, I want to use clip art in the foreground, like grass and other elements, which usually add a sense of depth.
                                        Alattab
                                        @pixelcruncher Thank you for your valuable efforts. You are accomplishing something great, and I will share my experience with you regularly.
                                        1 Reply Last reply ♥ Reply Quote 0
                                        • P Offline
                                          @Alattab
                                          As an aside, to quickly edit multiple lights, you can select multiple ones with CTRL / SHIFT + click and edit their properties at the same time.
                                          Regards,
                                          Thomas
                                          • P Offline
                                            Hey, Rayscaper users!
                                            Rayscaper 0.9.84 Beta is available. You can get it via:
                                            • The SketchUcation store.
                                            • Direct download: Rayscaper_Win_0.9.84_Beta.rbz.
                                            I recommend upgrading to the latest version.
                                            What Changed?
                                            • Add animation completion dialog. When a scene animation finishes rendering, a dialog now displays render statistics including total time, samples rendered, and frames completed.
                                            • Fix crash when minimizing the Rayscaper window via Windows "Show Desktop" (Win+D). The application now handles minimized states gracefully.
                                            • Improve scene archiving by extracting SketchUp embedded textures when external files are not available. This ensures textures are always included in exported archives.
                                            Help Me Build the Community 👍
                                            If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                                            Follow me on X.
                                            Happy Rendering!
                                            Thomas
                                            A 1 Reply Last reply 😑 👍 Reply Quote 1
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 18 / 22
