    Nvidia Card Causing System Freezes?
    19 Posts 7 Posters 1.6k Views 7 Watching
    • Joe WoodJ
      Joe Wood
      Folks, I’m not knowledgeable about this so bear with me!
      I got a very nice gaming desktop with a nice Nvidia card, to run my SUp. Soon after I got it I started getting system freezes. A computer tech said I had to reinstall the OS, so we did. He also said the installed integrated video card was way better than the Nvidia so he removed it.
      No more freezes! I used the computer for a couple weeks, and SUp was running better then ever! So I decided I wanted the Nvidia card reinstalled, and the freezes started again …
      Is the card bad, or is it causing a conflict somewhere? How can I troubleshoot this problem??
      Acer ET322QU (2560x1440@59Hz)
      Acer H236HL (1920x1080@60Hz)
      Intel UHD Graphics 750 (Dell)
      4095MB NVIDIA GeForce RTX 3060 Ti (Dell) 41 °C
      SLI Disabled
      Joe Wood
      woodsshop.com/
      • Gus RG
        Gus R
        Joe, I built my own desktop and had a few hair raising issues along the way.
        I don't know how to check for PSU wattage other than a physical inspection or maybe your computer documentation. It could be a faulty PSU or not enough power. I recommend a minimum of 750 watts.
        I was thinking it could be a faulty GPU in either the processors, chip, or even thermal paste issues. You can check temperature with MSI Afterburner which you can find on the internet. Just use it for reading the GPU temperature and avoid it for overclocking.
        I've had driver issues with my RTX 3060 but that usually just involved the screen going black for a second and re-setting. I typically uninstall the Nvidia Driver direct from Windows and then use Display Driver Uninstaller (DDU) in Safe Mode to uninstall the drivers. Make sure to check "Prevent download of drivers..." at the very bottom under options. I only install the display driver from Nvidia since I don't need the rest.
        It doesn't sound like a driver issue. Something is likely wrong with the GPU itself. It's like winning the lottery only a bad one. Reinstalling the OS for this issue was unnecessary.
        MSI Afterburner
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
          If you have GeForce Experience installed check for driver updates. Its usually in your system tray...
          https://i.imgur.com/4lYeMTR.png
          Update drivers as needed.
          If problem persists I'd ask for a GPU change to rule out stuttering.
          Its not something you can diagnose on the internet. If the computer tech is blowing smoke try a different tech shop and get a different opinion. Removing a GPU is not a solution to a problem its a side step around it.
          • Joe WoodJ
            Joe Wood
            Yeah it's updated. Maybe I should update the intergrated card.
            which of these would I update?
            Joe Wood
            woodsshop.com/
            • Joe WoodJ
              Joe Wood
              OK the only two acer drivers I can find are for-
              Monitor Drivers and
              Energy Efficiency Label
              neither sound like a graphic card update?
              Joe Wood
              woodsshop.com/
                Your GPU driver should be v 546.65
                Those other drivers won't affect GPU so I can't say whether or not they'll address the stuttering issue.
                To be honest it sounds systemic and the fact the techie says a GPU is not needed does raise an alarm.
                • Gus RG
                  Gus R
                  What's the wattage on your power supply?
                  • Joe WoodJ
                    Joe Wood
                    No idea Gus, how do I find that?
                    Dell sent a tech out 2 weeks ago and they replaced that and the motherboard.
                    I did a dell scan and it shows a Warning for the card ..
                    what a damn hassle, I get a nice new computer, and have nothing but problems.
                    Joe Wood
                    woodsshop.com/
                    • Joe WoodJ
                      Joe Wood
                      Yeah thanmks Gus but I'm afraid of doing these things myself, I'm pretty good at swinging a hammer, but not fixing computers!
                      I might just uninstall that NVid card, it was working very well without it.
                      Joe Wood
                      woodsshop.com/
                      • Gus RG
                        Gus R
                        Joe, OK, but make sure and get it replaced since you paid for it.
                        • A
                          anto76ny
                          I might just uninstall that NVid card, it was working very well without it here.
                          Most likely, both video cards tried to simultaneously control the display, which is why it froze.
                          • D
                            deanbuckeridge
                            Did you ever sort this issue? I have recently bought a new high spec i9 computer with a GeForce 4090 GPU. I took it back after a few days because it was constantly crashing and they haven't been able to isolate the issue after replacing cpu, gpu, motherboard and ram.
                            They've just had another similar build come back from a company working in geo engineering with similar issues, and they are now asking the question whether there might be an issue with SketchUp and DDR5 ram.
                            Is that something you looked at?
                            Joe WoodJ 1 Reply Last reply
                            • Joe WoodJ
                              Joe Wood @deanbuckeridge
                              @deanbuckeridge we just took out the nvidia card and it runs OK but still issues so I'm getting a new computer in about a week, no idea what was wrong but it is a refurbished machine.
                              Joe Wood
                              woodsshop.com/
                              D 1 Reply Last reply
                              • D
                                deanbuckeridge @Joe Wood
                                @Joe-Wood The shop solved my problem, changed the motherboard to a different type. Exactly what that fixed they could not say, just that there must have been an incompatibility somewhere.
                                Bryan KB 1 Reply Last reply
                                • Bryan KB
                                  Bryan K @deanbuckeridge
                                  @deanbuckeridge said in Nvidia Card Causing System Freezes?:
                                  Component compatibility issues are a rabbit hole.
                                  Often, two GPUs from different makers do not play nice together. In your case, it sounded like the motherboard was causing the issue. If that did solve it long term, than the issue with the motherboard could been many things. Bad from factory, not compatibile for those two GPUs running at the same time, bad bus I/O handling and so on.
                                  Glad to hear it was fixed.
                                  • Joe WoodJ
                                    Joe Wood @Bryan K
                                    @Bryan-K well not completely fixed so I'm just getting a new puter, this time from the factory and not refurbished!
                                    Joe Wood
                                    woodsshop.com/
                                    G 1 Reply Last reply
                                    • G
                                      Glenn at home @Joe Wood
                                      @Joe-Wood Sorry to hear about your troubles Joe. I only advise for people who are pretty good with technology in getting refurb systems. 8 out of 10 times they are usually good deals but issues can come up. My last home box was a Dell refurb from NewEgg.com and it was rock solid for 6 years. It was a base unit and I added in ssd and graphics card but I am confident in my abilities to do so. I hope your new system works better for you. Thanks for sharing your designs as well.
                                      • Joe WoodJ
                                        Joe Wood @Glenn at home
                                        @Glenn-at-home was it Yor who recommended it?!
                                        yeah what a hassle, kept throwing money at it with a local tech,
                                        but don't feel too bad about it! 🙂 Just joking ..
                                        Joe Wood
                                        woodsshop.com/
                                        • G
                                          @Joe-Wood Oops, I might have and if I did I'm sorry. 😉
