    Nvidia Card Causing System Freezes?
    19 Posts 7 Posters 1.6k Views 7 Watching
    • Joe WoodJ
      Joe Wood
      Yeah it's updated. Maybe I should update the intergrated card.
      which of these would I update?
      Acer ET322QU (2560x1440@59Hz)
      Acer H236HL (1920x1080@60Hz)
      Intel UHD Graphics 750 (Dell)
      Joe Wood
      woodsshop.com/
      • Joe WoodJ
        Joe Wood
        OK the only two acer drivers I can find are for-
        Monitor Drivers and
        Energy Efficiency Label
        neither sound like a graphic card update?
        Joe Wood
        woodsshop.com/
          Your GPU driver should be v 546.65
          Those other drivers won't affect GPU so I can't say whether or not they'll address the stuttering issue.
          To be honest it sounds systemic and the fact the techie says a GPU is not needed does raise an alarm.
          • Gus RG
            Gus R
            What's the wattage on your power supply?
            www.instagram.com/gusrobatto/
            www.facebook.com/gusrobatto
            • Joe WoodJ
              Joe Wood
              No idea Gus, how do I find that?
              Dell sent a tech out 2 weeks ago and they replaced that and the motherboard.
              I did a dell scan and it shows a Warning for the card ..
              what a damn hassle, I get a nice new computer, and have nothing but problems.
              Joe Wood
              woodsshop.com/
              • Joe WoodJ
                Joe Wood
                Yeah thanmks Gus but I'm afraid of doing these things myself, I'm pretty good at swinging a hammer, but not fixing computers!
                I might just uninstall that NVid card, it was working very well without it.
                Joe Wood
                woodsshop.com/
                • Gus RG
                  Gus R
                  Joe, OK, but make sure and get it replaced since you paid for it.
                    anto76ny
                    I might just uninstall that NVid card, it was working very well without it here.
                    Most likely, both video cards tried to simultaneously control the display, which is why it froze.
                      deanbuckeridge
                      Did you ever sort this issue? I have recently bought a new high spec i9 computer with a GeForce 4090 GPU. I took it back after a few days because it was constantly crashing and they haven't been able to isolate the issue after replacing cpu, gpu, motherboard and ram.
                      They've just had another similar build come back from a company working in geo engineering with similar issues, and they are now asking the question whether there might be an issue with SketchUp and DDR5 ram.
                      Is that something you looked at?
                      Joe WoodJ 1 Reply Last reply
                      • Joe WoodJ
                        Joe Wood @deanbuckeridge
                        @deanbuckeridge we just took out the nvidia card and it runs OK but still issues so I'm getting a new computer in about a week, no idea what was wrong but it is a refurbished machine.
                        Joe Wood
                        woodsshop.com/
                        D 1 Reply Last reply
                          deanbuckeridge @Joe Wood
                          @Joe-Wood The shop solved my problem, changed the motherboard to a different type. Exactly what that fixed they could not say, just that there must have been an incompatibility somewhere.
                          Bryan KB 1 Reply Last reply
                          • Bryan KB
                            Bryan K @deanbuckeridge
                            @deanbuckeridge said in Nvidia Card Causing System Freezes?:
                            Component compatibility issues are a rabbit hole.
                            Often, two GPUs from different makers do not play nice together. In your case, it sounded like the motherboard was causing the issue. If that did solve it long term, than the issue with the motherboard could been many things. Bad from factory, not compatibile for those two GPUs running at the same time, bad bus I/O handling and so on.
                            Glad to hear it was fixed.
                            • Joe WoodJ
                              Joe Wood @Bryan K
                              @Bryan-K well not completely fixed so I'm just getting a new puter, this time from the factory and not refurbished!
                              Joe Wood
                              woodsshop.com/
                              G 1 Reply Last reply
                              • G
                                Glenn at home @Joe Wood
                                @Joe-Wood Sorry to hear about your troubles Joe. I only advise for people who are pretty good with technology in getting refurb systems. 8 out of 10 times they are usually good deals but issues can come up. My last home box was a Dell refurb from NewEgg.com and it was rock solid for 6 years. It was a base unit and I added in ssd and graphics card but I am confident in my abilities to do so. I hope your new system works better for you. Thanks for sharing your designs as well.
                                • Joe WoodJ
                                  Joe Wood @Glenn at home
                                  @Glenn-at-home was it Yor who recommended it?!
                                  yeah what a hassle, kept throwing money at it with a local tech,
                                  but don't feel too bad about it! πŸ™‚ Just joking ..
                                  Joe Wood
                                  woodsshop.com/
                                  • G
                                    @Joe-Wood Oops, I might have and if I did I'm sorry. πŸ˜‰
