    Batch conversion from jpg to PNG
    5 Posts 4 Posters 421 Views 4 Watching
      Hi All I am trying to batch convert materials from jpg to PNG. I am using windows image converter. The reason I need to do this is that I have files from Globe plants that need to be converted from jpg
      to PNG so I get an alpha channel for the leaves of the plants, there are many images πŸ˜• Any way I am hoping somebody here may have some experience with this. I have attached an image.
      Seems pretty simple, but when I try to use the option overweight existing it just goes back to "click to choose" I assume that means that it will overwrite the Jpg's with the PNG conversion but I cant make it happen any ideas please?
        I use FFMPEG but that requires some setup via the terminal.
        You could use Riot to batch process too...
        https://riot-optimizer.com/
        JPG to PNG will bloat file size
        • Gus RG Offline
          Gus R
          I've used the Batch Image Manipulation Plugin with Gimp and it works pretty fast and uses folders. Didn't use it for alpha channels.
          This is the link for BIMP: https://alessandrofrancesconi.it/projects/bimp/
          www.instagram.com/gusrobatto/
          www.facebook.com/gusrobatto
          • gullfoG Offline
            gullfo
            irfanview. https://www.irfanview.com/main_download_engl.htm
            Glenn
            http://www.runnel.com
              Thanks guys πŸ‘ πŸ‘
