    Twinmotion interior render
    14 Posts 8 Posters 441 Views 8 Watching
      I gave TM a miss for a while as my graphics card was not up to the new version, I was very rusty. I decided to practice interior work as I dont need fog and decals which are now fixed in TM with path trace on. This render relied heavely on an image from Matt Interiors with some minor changes.
      (Edited) I think I prefere the desaturated image
        Really nice lighting and textures/materials. Top notch output.
        My only observation is the noticeable texture tiling for the wood. Those 3 knots at eye level in particular.
          Brilliant. πŸ‘Š
            Thanks Rich and Mike. You have a great eye Rich and I would normally fix the tile on the wood material but I will be lazy as it is a timber vaneer and mirroring is common πŸ˜‰
            • BoxB Offline
              Looks good, I made my minor criticisms elsewhere.
                Yes I saw mate, and agree the optical illusion caused by the chevron flooring. I will change that. I will go with a linear floor. I was going for more normals effect but it backfired. TM is strange when a normals map is used is has a preset of 100% which is actually quite stupid as TM does not know the effect (Power) of the normals map. The preset should be 50% common sense
                • jo-keJ Offline
                  jo-ke
                  very nice one.
                  http://www.zz7.de
                    @jo-ke said:
                    very nice one.
                    Thanks mate
                    • alvisA Offline
                      alvis
                      Wow! πŸ‘
                        I lean towards the more saturated image. More punchy vibe.
                        Newer one is nice too. I wonder what my opinion would've been if you posted the revision first?
                        Beauty is in the eye of the beerholder
                          I go throuh a hard time fine tunning thats why I post as I cannot se the forrest for the trees at the end and get confused. Thats why I post πŸ˜•
                          • marked001M Offline
                            marked001
                            Very nice.... I was really torn between getting TM and lumion.
                            I prefer the saturated image as well πŸ˜„
                            http://www.revision21vis.com
                            instagram: revi21on
                            • Bryan KB Offline
                              Both pictures are excellent! πŸ‘
                              • jo-keJ Offline
                                jo-ke
                                here took somebody the same scene and rendered it in twinmotion:
                                http://www.zz7.de
