πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Twinmotion interior render
14 Posts 8 Posters 5 Views
    I gave TM a miss for a while as my graphics card was not up to the new version, I was very rusty. I decided to practice interior work as I dont need fog and decals which are now fixed in TM with path trace on. This render relied heavely on an image from Matt Interiors with some minor changes.
    (Edited) I think I prefere the desaturated image
      Really nice lighting and textures/materials. Top notch output.
      My only observation is the noticeable texture tiling for the wood. Those 3 knots at eye level in particular.
        Brilliant. πŸ‘Š
          Thanks Rich and Mike. You have a great eye Rich and I would normally fix the tile on the wood material but I will be lazy as it is a timber vaneer and mirroring is common πŸ˜‰
            Looks good, I made my minor criticisms elsewhere.
              Yes I saw mate, and agree the optical illusion caused by the chevron flooring. I will change that. I will go with a linear floor. I was going for more normals effect but it backfired. TM is strange when a normals map is used is has a preset of 100% which is actually quite stupid as TM does not know the effect (Power) of the normals map. The preset should be 50% common sense
                jo-ke
                very nice one.
                http://www.zz7.de
                  @jo-ke said:
                  very nice one.
                  Thanks mate
                    alvis
                    Wow! πŸ‘
                      I lean towards the more saturated image. More punchy vibe.
                      Newer one is nice too. I wonder what my opinion would've been if you posted the revision first?
                      Beauty is in the eye of the beerholder
                        I go throuh a hard time fine tunning thats why I post as I cannot se the forrest for the trees at the end and get confused. Thats why I post πŸ˜•
                          marked001
                          Very nice.... I was really torn between getting TM and lumion.
                          I prefer the saturated image as well πŸ˜„
                          http://www.revision21vis.com
                          instagram: revi21on
                            Both pictures are excellent! πŸ‘
                              jo-ke
                              here took somebody the same scene and rendered it in twinmotion:
                              http://www.zz7.de
