    3D Printed Screw Threads
    23 Posts 6 Posters 2.2k Views 6 Watching
      I did this model of a small machinist's jack a while back. Decided to 3D print it on my new printer yesterday. The machine screw threads work perfectly. Overall height with the screw fully retracted is 3 inches.
      https://live.staticflickr.com/7908/46303997635_d6b7e037c5_b.jpg
      https://live.staticflickr.com/65535/52844033375_61cf1220ee_b.jpg
      https://live.staticflickr.com/65535/52843628886_678aca87bc_b.jpg
      • ntxdaveN Offline
        ntxdave
        Nice work Dave - thanks for sharing images of the β€œprinted” products. πŸ‘ πŸ‘
        Press F1...thank me later
          Thanks.
          I need to get some gray filament for these things. This white PLA came with the printer and I've got some black but they are both difficult to photograph well.
          • Rich O BrienR Online
            That's nuts
            I'd be interested to know the lifespan of these. Plus the file size of the skp as that knurling is gnarly!
            • HornOxxH Offline
              HornOxx
              ...I always love this facet cut(?)! great work, both in SkUp and in print πŸ‘
              never trust a skinny cook
                Thank you. Lifespan is suspect at least in use. In this print there's only 10% infill on the base unit so I'd expect it wouldn't be durable in a shop.
                The SketchUp model file for all four parts is 1.5 Mb.
                Thank you, too, HornOxx.
                • tuna1957T Offline
                  tuna1957
                  Great job πŸ‘
                    https://live.staticflickr.com/65535/53074122719_0f0aa74973_b.jpg
                    Another little planer jack to add to the collection.
                      More screw threads. The nuts and bolts are threaded 8mm.
                      https://live.staticflickr.com/65535/53091698618_4678f0ff7c_b.jpg
                      https://live.staticflickr.com/65535/53090643927_65c2859046_b.jpg
                      • tuna1957T Offline
                        tuna1957
                        Dave , your mechanical bits never cease to amaze and delight me. πŸ‘ πŸ‘ πŸ‘
                          Thank you sir.
                            More screw threads. These are 23mm long.
                            https://live.staticflickr.com/65535/53242961931_a6a8cdb20f_b.jpg
                            They are for a model of a U-joint from around 1900.
                            https://live.staticflickr.com/65535/51683190468_4a7c78b35e_b.jpg
                            The center ball and short pieces of the shafts have been printed. Yokes are printing now. Looks like I managed to get the screws dirty fitting them into the holes in the ball. I haven't decided it I'll print the tapered pins or make them a different way.
                            • ntxdaveN Offline
                              ntxdave
                              I agree with tuna57 completely. πŸ‘ πŸ‘ πŸ‘
                                Thank you.
                                  Finished except for the tapered pins.
                                  https://live.staticflickr.com/65535/53244408849_88f399eb9c_b.jpg
                                  • ntxdaveN Offline
                                    ntxdave
                                    Nice πŸ‘ πŸ‘
                                    • HornOxxH Offline
                                      HornOxx
                                      klasse! πŸ‘
                                        rspierenburg
                                        Hey this is awesome, just a quick question. What do you typically use for tolerances between the nut and bolt? I know it depends on the printer but just wanted to get a baseline idea.
                                        Robert
                                          Thanks.
                                          I nrmally model the internal and external threads to the specifications given for the thread type and class. In some cases if I'm feeling lazy, I just scale up the internal threads by 1.02 or 1.03 in X and Y without scaling Z. I've found I can't be lazy with Acme and square threads, though. Scaling doesn't work for them. They have to be modeled correctly.
                                            M6 x 1.0 screws. I didn't have any short enough metal ones on hand and it was faster to print a couple than go to buy some for this proof of concept thing.
                                            • 1 / 2
