    3D Printed Screw Threads
    23 Posts 6 Posters 2.3k Views 6 Watching
    • HornOxxH Offline
      HornOxx
      ...I always love this facet cut(?)! great work, both in SkUp and in print πŸ‘
      never trust a skinny cook
        @rich o brien said:
        I'd be interested to know the lifespan of these. Plus the file size of the skp as that knurling is gnarly!
        Thank you. Lifespan is suspect at least in use. In this print there's only 10% infill on the base unit so I'd expect it wouldn't be durable in a shop.
        The SketchUp model file for all four parts is 1.5 Mb.
        Thank you, too, HornOxx.
        • tuna1957T Offline
          tuna1957
          Great job πŸ‘
            https://live.staticflickr.com/65535/53074122719_0f0aa74973_b.jpg
            Another little planer jack to add to the collection.
              More screw threads. The nuts and bolts are threaded 8mm.
              https://live.staticflickr.com/65535/53091698618_4678f0ff7c_b.jpg
              https://live.staticflickr.com/65535/53090643927_65c2859046_b.jpg
              • tuna1957T Offline
                tuna1957
                Dave , your mechanical bits never cease to amaze and delight me. πŸ‘ πŸ‘ πŸ‘
                  Thank you sir.
                    More screw threads. These are 23mm long.
                    https://live.staticflickr.com/65535/53242961931_a6a8cdb20f_b.jpg
                    They are for a model of a U-joint from around 1900.
                    https://live.staticflickr.com/65535/51683190468_4a7c78b35e_b.jpg
                    The center ball and short pieces of the shafts have been printed. Yokes are printing now. Looks like I managed to get the screws dirty fitting them into the holes in the ball. I haven't decided it I'll print the tapered pins or make them a different way.
                    • ntxdaveN Offline
                      ntxdave
                      I agree with tuna57 completely. πŸ‘ πŸ‘ πŸ‘
                      Press F1...thank me later
                        Thank you.
                          Finished except for the tapered pins.
                          https://live.staticflickr.com/65535/53244408849_88f399eb9c_b.jpg
                          • ntxdaveN Offline
                            ntxdave
                            Nice πŸ‘ πŸ‘
                            • HornOxxH Offline
                              HornOxx
                              klasse! πŸ‘
                                rspierenburg
                                Hey this is awesome, just a quick question. What do you typically use for tolerances between the nut and bolt? I know it depends on the printer but just wanted to get a baseline idea.
                                Robert
                                  Thanks.
                                  I nrmally model the internal and external threads to the specifications given for the thread type and class. In some cases if I'm feeling lazy, I just scale up the internal threads by 1.02 or 1.03 in X and Y without scaling Z. I've found I can't be lazy with Acme and square threads, though. Scaling doesn't work for them. They have to be modeled correctly.
                                    M6 x 1.0 screws. I didn't have any short enough metal ones on hand and it was faster to print a couple than go to buy some for this proof of concept thing.
                                      https://live.staticflickr.com/65535/53391926720_f74ba60dde_b.jpg
                                      https://live.staticflickr.com/65535/53391797614_ee10429139_b.jpg
                                        I'd find it hard to resist the urge to hit that with a heat gun to smooth it out.
                                        Crazy accurate modelling. Does it hold a seal?
                                          I would like to do something to smooth it out but it's fine as it is. The threads have a fit typical of metal ones but it won't whistle. I think because the PLA doesn't resonate like bronze, brass, or iron would.
                                          I expect I could run steam through it. Once.
