    3D Printed Screw Threads
    23 Posts 6 Posters 2.8k Views 6 Watching
      I did this model of a small machinist's jack a while back. Decided to 3D print it on my new printer yesterday. The machine screw threads work perfectly. Overall height with the screw fully retracted is 3 inches.
      https://live.staticflickr.com/7908/46303997635_d6b7e037c5_b.jpg
      https://live.staticflickr.com/65535/52844033375_61cf1220ee_b.jpg
      https://live.staticflickr.com/65535/52843628886_678aca87bc_b.jpg
      • ntxdaveN
        ntxdave
        Nice work Dave - thanks for sharing images of the “printed” products. 👍 👍
        Press F1...thank me later
          Thanks.
          I need to get some gray filament for these things. This white PLA came with the printer and I've got some black but they are both difficult to photograph well.
            That's nuts
            I'd be interested to know the lifespan of these. Plus the file size of the skp as that knurling is gnarly!
            • HornOxxH
              HornOxx
              ...I always love this facet cut(?)! great work, both in SkUp and in print 👍
              never trust a skinny cook
                Thank you. Lifespan is suspect at least in use. In this print there's only 10% infill on the base unit so I'd expect it wouldn't be durable in a shop.
                The SketchUp model file for all four parts is 1.5 Mb.
                Thank you, too, HornOxx.
                • tuna1957T
                  tuna1957
                  Great job 👍
                    https://live.staticflickr.com/65535/53074122719_0f0aa74973_b.jpg
                    Another little planer jack to add to the collection.
                      More screw threads. The nuts and bolts are threaded 8mm.
                      https://live.staticflickr.com/65535/53091698618_4678f0ff7c_b.jpg
                      https://live.staticflickr.com/65535/53090643927_65c2859046_b.jpg
                      • tuna1957T
                        tuna1957
                        Dave , your mechanical bits never cease to amaze and delight me. 👍 👍 👍
                          Thank you sir.
                            More screw threads. These are 23mm long.
                            https://live.staticflickr.com/65535/53242961931_a6a8cdb20f_b.jpg
                            They are for a model of a U-joint from around 1900.
                            https://live.staticflickr.com/65535/51683190468_4a7c78b35e_b.jpg
                            The center ball and short pieces of the shafts have been printed. Yokes are printing now. Looks like I managed to get the screws dirty fitting them into the holes in the ball. I haven't decided it I'll print the tapered pins or make them a different way.
                            • ntxdaveN
                              ntxdave
                              I agree with tuna57 completely. 👍 👍 👍
                                Thank you.
                                  Finished except for the tapered pins.
                                  https://live.staticflickr.com/65535/53244408849_88f399eb9c_b.jpg
                                  • ntxdaveN
                                    ntxdave
                                    Nice 👍 👍
                                    • HornOxxH
                                      HornOxx
                                      klasse! 👍
                                        rspierenburg
                                        Hey this is awesome, just a quick question. What do you typically use for tolerances between the nut and bolt? I know it depends on the printer but just wanted to get a baseline idea.
                                        Robert
                                          Thanks.
                                          I nrmally model the internal and external threads to the specifications given for the thread type and class. In some cases if I'm feeling lazy, I just scale up the internal threads by 1.02 or 1.03 in X and Y without scaling Z. I've found I can't be lazy with Acme and square threads, though. Scaling doesn't work for them. They have to be modeled correctly.
                                            M6 x 1.0 screws. I didn't have any short enough metal ones on hand and it was faster to print a couple than go to buy some for this proof of concept thing.
