    License Round Corner error
    15 Posts 6 Posters 883 Views 6 Watching
      Thiago Luz
      Hello... I'm having problems validating the license for the round corners plugin... I paid, everything is ok, I got the license but when I try to validate it, the program reports an error... can someone help me please?
      I don't know if it has to do with program versions, but when searching for the program it lands on a version, you download it, you have the option to buy the license... anyway... I don't know what's wrong
        Thiago Luz
        image showing error loading license
        Error
          The SCF license version shown in the screenshot of the dialog is out of date.
          Install the latest version of the SketchUcation toolset - this has the newest SCF licensing code.
          Then restart SketchUp to sync everything...
          Also check that you have the newest version of LibFredo installed...
            Thiago Luz
            I updated everything you commented... the error unfortunately continues...
            • Rich O BrienR Online
              You have a license for RoundCorner. Not FredoCorner.
              https://i.imgur.com/0c3yEDq.png
                Thiago Luz
                the problem continues...
                  Thiago Luz
                    Likely your firewall, network, antivirus blocking communication.
                    Disable or whitelist *.sketchucation.com so activation can happen.
                      Thiago Luz
                      it worked buddy, thanks everyone for the help!!!
                      • G Offline
                        guess15
                        please help with the licensing validation. need it badly. i am working on an urgent project. kindly response ASAP
                          Please explain your problem.
                          Also, go to Window > Libfredo Settings > .....Sketchucation Support
                          Paste the text output here.
                            jcardozoch Newcomers
                            Hi Thiago,,
                            I am having the same problem
                            Did you get it to work?
                              barrosmobiliario Newcomers
                              It's giving me an error with the round corner license, how can I solve it?
                              Fredo6 Plugins Information on 2023-11-29 08:37:33 +0000
                              • Platform: x64-mswin64_140 - Ruby: 2.7.7
                              • Sketchup: 23.1.340
                              • LibFredo6: v14.2a
                              • LibFredo6 Binary loaded
                              • Sketchucation ExtensionStore: 4.3.1
                              • SCFLicense: v6.1a - 72
                              • Fredo6 Plugins
                                FredoScale v3.5a
                                RoundCorner v3.3a
                              • SCFLicense directory present
                                Signature File: 2023-11-28 19:57:26 +0000
                                Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                  • LibFredo6: v14.2a
                                  • Fredo6 Plugins
                                    FredoScale v3.5a
                                    RoundCorner v3.3a
                                  • Close SketchUp
                                  • Please delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file at C:\Users\SomeName\AppData\Local\SCF Licenses
                                  • Open SketchUp
                                  • Validate using license files at https://sketchucation.com/webshop/my-licences.php
