    License Round Corner error
    15 Posts 6 Posters 1.8k Views 6 Watching
    • T
      Thiago Luz
      image showing error loading license
      Error
        The SCF license version shown in the screenshot of the dialog is out of date.
        Install the latest version of the SketchUcation toolset - this has the newest SCF licensing code.
        Then restart SketchUp to sync everything...
        Also check that you have the newest version of LibFredo installed...
        • T
          Thiago Luz
          I updated everything you commented... the error unfortunately continues...
            You have a license for RoundCorner. Not FredoCorner.
            https://i.imgur.com/0c3yEDq.png
            • T
              Thiago Luz
              the problem continues...
              • T
                Thiago Luz
                  Likely your firewall, network, antivirus blocking communication.
                  Disable or whitelist *.sketchucation.com so activation can happen.
                  • T
                    Thiago Luz
                    it worked buddy, thanks everyone for the help!!!
                    • G
                      guess15
                      please help with the licensing validation. need it badly. i am working on an urgent project. kindly response ASAP
                        Please explain your problem.
                        Also, go to Window > Libfredo Settings > .....Sketchucation Support
                        Paste the text output here.
                          jcardozoch Newcomers
                          Hi Thiago,,
                          I am having the same problem
                          Did you get it to work?
                          • B
                            barrosmobiliario Newcomers
                            It's giving me an error with the round corner license, how can I solve it?
                            Fredo6 Plugins Information on 2023-11-29 08:37:33 +0000
                            • Platform: x64-mswin64_140 - Ruby: 2.7.7
                            • Sketchup: 23.1.340
                            • LibFredo6: v14.2a
                            • LibFredo6 Binary loaded
                            • Sketchucation ExtensionStore: 4.3.1
                            • SCFLicense: v6.1a - 72
                            • Fredo6 Plugins
                              FredoScale v3.5a
                              RoundCorner v3.3a
                              Signature File: 2023-11-28 19:57:26 +0000
                              Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                • LibFredo6: v14.2a
                                • Fredo6 Plugins
                                  FredoScale v3.5a
                                  RoundCorner v3.3a
                                • Close SketchUp
                                • Please delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file at C:\Users\SomeName\AppData\Local\SCF Licenses
                                • Open SketchUp
                                • Validate using license files at https://sketchucation.com/webshop/my-licences.php
