    License Round Corner error
    15 Posts 6 Posters 839 Views 6 Watching
      Thiago Luz
      Hello... I'm having problems validating the license for the round corners plugin... I paid, everything is ok, I got the license but when I try to validate it, the program reports an error... can someone help me please?
      I don't know if it has to do with program versions, but when searching for the program it lands on a version, you download it, you have the option to buy the license... anyway... I don't know what's wrong
        Thiago Luz
        image showing error loading license
        Error
        • TIGT Online
          The SCF license version shown in the screenshot of the dialog is out of date.
          Install the latest version of the SketchUcation toolset - this has the newest SCF licensing code.
          Then restart SketchUp to sync everything...
          Also check that you have the newest version of LibFredo installed...
            Thiago Luz
            I updated everything you commented... the error unfortunately continues...
            • Rich O BrienR Online
              You have a license for RoundCorner. Not FredoCorner.
              https://i.imgur.com/0c3yEDq.png
                Thiago Luz
                the problem continues...
                  Thiago Luz
                    Likely your firewall, network, antivirus blocking communication.
                    Disable or whitelist *.sketchucation.com so activation can happen.
                      Thiago Luz
                      it worked buddy, thanks everyone for the help!!!
                        guess15
                        please help with the licensing validation. need it badly. i am working on an urgent project. kindly response ASAP
                          Please explain your problem.
                          Also, go to Window > Libfredo Settings > .....Sketchucation Support
                          Paste the text output here.
                            jcardozoch Newcomers
                            Hi Thiago,,
                            I am having the same problem
                            Did you get it to work?
                              barrosmobiliario Newcomers
                              It's giving me an error with the round corner license, how can I solve it?
                              Fredo6 Plugins Information on 2023-11-29 08:37:33 +0000
                              • Platform: x64-mswin64_140 - Ruby: 2.7.7
                              • Sketchup: 23.1.340
                              • LibFredo6: v14.2a
                              • LibFredo6 Binary loaded
                              • Sketchucation ExtensionStore: 4.3.1
                              • SCFLicense: v6.1a - 72
                              • Fredo6 Plugins
                                FredoScale v3.5a
                                RoundCorner v3.3a
                                Signature File: 2023-11-28 19:57:26 +0000
                                Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                  • LibFredo6: v14.2a
                                  • Fredo6 Plugins
                                    FredoScale v3.5a
                                    RoundCorner v3.3a
                                  • Close SketchUp
                                  • Please delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file at C:\Users\SomeName\AppData\Local\SCF Licenses
                                  • Open SketchUp
                                  • Validate using license files at https://sketchucation.com/webshop/my-licences.php
