    ExtensionStore empty
    6 Posts 3 Posters 3.1k Views 3 Watching
    • grizzlerG Offline
      grizzler
      I've just downloaded ExtensionsStore v4.2.9 so I can get my Fredo6 license and it just comes up blank. I've restarted SU and turned off my VPN but it just remains blank for a while and then says " Navigation to web page was cancelled". If I then click on "refresh page" it says "This site is not secure. This might mean that someone’s trying to fool you or steal any info you send to the server. You should close this site immediately." - Any suggestions?
      Everything else is working fine for me, my connection is stable and decent speed.
        We have a valid SSL certificate...
        https://i.imgur.com/2nqScIu.png
        ...and your message is suggesting it is accessing an unsecure URL. Have you tried clearing your cookies and cache from your browser/s and retrying?
        You should not get that message. Are you using a VPN or strict Firewall?
          Sounds like an over-zealous virus tool's firewall that is blocking the site.
          Obviously the thousands of members using it have no issues...
          Over certificates etc are up to date.
          Has something changed with your set up recently ?
          Have you checked to see where you can 'white-list' the site ?
          The two that need access are
          sketchucation.com
          plugin.sketchucation.com
          in particular the
          https://plugin.sketchucation.com/pluginstore_4.php
          Rich's cache deletion is a good idea, but note how it relates to the cache used by IE/Edge [Internet Options] and not anything else used by another default web-browser...
            @grizzler said:
            Device Association Framework Provider Host
            Remote Address: 239.255.255.250
            What do you think?
            I don't know what that IP address is but its not us. Our IP is...
            144.76.69.227 (static.227.69.76.144.clients.your-server.de)
            • grizzlerG Offline
              grizzler
              It doesn't seem to be my browser but it might be my firewall, it's blocked the following today and I'm wondering whether it might be what I need - I don't want to whitelist it without knowing though:
              What do you think?
              I just deactivated my firewall and tried again but I still get blocked
              • grizzlerG Offline
                grizzler
                Finally! It has taken me 24 hours of disabling and enabling everything I can, numerous restarts, cache clearances etc, and the thing that finally worked was to enable my VPN and set it to a US server, suddenly all my problems were solved! I've no idea why this worked but it did and I'm not going to question it in case I jinx it
