    [Solved] Ques. Making a array of progressively sized objects
    6 Posts 4 Posters 2.4k Views 4 Watching
      spreadcore
      Note Using SUmake 2017, Windows
      Ques.Is there a plugin or simpler way to create a object array where the size of the object progressively increases (or decreases) to the end? Maybe have some inputs regarding how much the increase is (10%, 20%, etc.) or maybe set a target end size and let it generate the in between sizes.
      In this example I did a normal array, grouped them and then used Fredoscale:Box Taper.
      This result was okay, but the sides of the cylinders became tapered and I'd like them to stay parallel.
      Progressive size array example
      • Rich O BrienR Online
        https://sketchucation.com/pluginstore?pln=Grow
        Play around with the settings and you'll get what you need.
          Set Scaling to YES to be able to scale your copies....
          https://i.imgur.com/Yc0mhgs.png
          thus revealing the pièce de résistance of dialogs...
          https://i.imgur.com/DPgpM0T.png
            spreadcore
            Hi Rich, Thank you for the prompt reply. Tried the plugin a few times and it looks like it will do the trick.
            • BoxB Offline
              I would have suggested Grow too.
              By there is always the manual option, useful if you are working in the web version.
              • ntxdaveN Offline
                ntxdave
                Nice one Box. 👍
                Press F1...thank me later
