    [Solved] Ques. Making a array of progressively sized objects
    6 Posts 4 Posters 2.4k Views 4 Watching
      spreadcore
      Note Using SUmake 2017, Windows
      Ques.Is there a plugin or simpler way to create a object array where the size of the object progressively increases (or decreases) to the end? Maybe have some inputs regarding how much the increase is (10%, 20%, etc.) or maybe set a target end size and let it generate the in between sizes.
      In this example I did a normal array, grouped them and then used Fredoscale:Box Taper.
      This result was okay, but the sides of the cylinders became tapered and I'd like them to stay parallel.
      Progressive size array example
      • Rich O BrienR Online
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        Play around with the settings and you'll get what you need.
          Set Scaling to YES to be able to scale your copies....
          https://i.imgur.com/Yc0mhgs.png
          thus revealing the pièce de résistance of dialogs...
          https://i.imgur.com/DPgpM0T.png
            spreadcore
            (sketchucation.com)
            Hi Rich, Thank you for the prompt reply. Tried the plugin a few times and it looks like it will do the trick.
            • BoxB Offline
              I would have suggested Grow too.
              By there is always the manual option, useful if you are working in the web version.
              • ntxdaveN Offline
                ntxdave
                Nice one Box. 👍
                Press F1...thank me later
