    Advice for Making a Winding, Organic Shape
    9 Posts 4 Posters 3.1k Views 4 Watching
    • A
      AshleyA
      Hi there! I created this winding shape in Illustrator and now I'm trying to develop it further and render it in Sketchup. It's proving to be much more complex than I realized. Any ideas on how I might go about this? What plug-ins should I use for a design like this? Any videos that would be helpful? Please see the attached screen captures (one of them is a plan view, the other a front view).
      Thanks in advance for any help!
      Ashley
      (EDIT): I've already started and tried to build this shape piece by piece (see attachment), but I keep getting these weird edges and I want the "winding" path to be smooth.
      Front View
      Plan View
      • HornOxxH
        HornOxx
        Hi!
        besides other solutions, for example Christina Eneroth´s "Upright Extruder" (which works in a similar way to the Follow Me tool, but much more sophisticated) and SketchUp´s native Solid Tools should hopefully work for your task
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        never trust a skinny cook
        • A
          AshleyA
          @hornoxx said:
          Hi!
          (sketchucation.com)
          HornOxx, thanks for the help! I tried your suggested plug-in and it did work, however, now it will not let me raise and lower the edges... I'd like for the shape to have these angles, not a flat top. I've attached screen capture... is there another plug-in for that? How would I raise and lower the edges to create angles on this shape?
          Thanks again!
          • boofredlayB
            boofredlay
            • boofredlayB
              boofredlay
              Only one plugin used. Vector Push pull in the JPP set.
              All other commands are native to SketchUp.
                Nice work Eric.
                • boofredlayB
                  boofredlay
                  Here is another, pretty much the same but it has the small arc in the middle of the shape before I rotated it.
                  • A
                    AshleyA
                    Thanks so much for sending this video Boofredlay! I'll give this a try! Very big help to visualize a solution to achieving this shape!
                    • A
                      AshleyA
                      @dave r said:
                      Nice work Eric.
                      Thanks for your suggestion earlier about the helix, Dave! I don't see the comment anymore, but I did download that plug-in and have been trying to learn how to use it and get it to work with the shape I need.
