    Advice for Making a Winding, Organic Shape
    9 Posts 4 Posters 2.9k Views 4 Watching
      AshleyA
      Hi there! I created this winding shape in Illustrator and now I'm trying to develop it further and render it in Sketchup. It's proving to be much more complex than I realized. Any ideas on how I might go about this? What plug-ins should I use for a design like this? Any videos that would be helpful? Please see the attached screen captures (one of them is a plan view, the other a front view).
      Thanks in advance for any help!
      Ashley
      (EDIT): I've already started and tried to build this shape piece by piece (see attachment), but I keep getting these weird edges and I want the "winding" path to be smooth.
      Front View
      Plan View
      • HornOxxH Offline
        HornOxx
        Hi!
        besides other solutions, for example Christina Eneroth´s "Upright Extruder" (which works in a similar way to the Follow Me tool, but much more sophisticated) and SketchUp´s native Solid Tools should hopefully work for your task
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        never trust a skinny cook
          AshleyA
          @hornoxx said:
          Hi!
          (sketchucation.com)
          HornOxx, thanks for the help! I tried your suggested plug-in and it did work, however, now it will not let me raise and lower the edges... I'd like for the shape to have these angles, not a flat top. I've attached screen capture... is there another plug-in for that? How would I raise and lower the edges to create angles on this shape?
          Thanks again!
          • boofredlayB Offline
            boofredlay
              boofredlay
              Only one plugin used. Vector Push pull in the JPP set.
              All other commands are native to SketchUp.
                Nice work Eric.
                  boofredlay
                  Here is another, pretty much the same but it has the small arc in the middle of the shape before I rotated it.
                    AshleyA
                    Thanks so much for sending this video Boofredlay! I'll give this a try! Very big help to visualize a solution to achieving this shape!
                      AshleyA
                      @dave r said:
                      Nice work Eric.
                      Thanks for your suggestion earlier about the helix, Dave! I don't see the comment anymore, but I did download that plug-in and have been trying to learn how to use it and get it to work with the shape I need.
