    [Plugin] LordOfTheToolbars - v4.1a - 20 Oct 26
    532 Posts 101 Posters 591.6k Views 99 Watching
    • C
      CGMen
      Hi everyone,
      I’ve noticed some odd behavior in SketchUp 2026.
      If I delete the folder of any Fredo6 plugin — for example, Fredo6_VisuHole — from the SketchUp Plugins directory in Roaming (only the folder, not the main RB/executable file), SketchUp throws the following error on startup:
      “Installation of Fredo6_VisuHole is probably incorrect. Subfolder is missing.”
      What’s strange is that LOTT and Vignette still work fine after this. It doesn’t matter which Fredo6 plugin folder I remove — the same thing happens.
      When I restore the deleted folder, SketchUp starts normally again, but then the behavior becomes the same as what Ramzix described earlier.
      • R
        Ramzix
        nope, just a small laptop
        • F
          FlorinAp
          There is a very old bug, the Vignette Stripe doesn't stay where you put it - after SU restart, it will reset its position to the default, whether you lock it or not, it will do the same thing.
          And another one (but i think this one may not have a solution), i have two Favorites Palettes that i use in compact mode as toolbars (horizontal stripes, permanently open), every time you minimize and maximize the SU window, these Palettes navigate about 1-2 mm to the left, until eventually you have to move them back..., and so on.
          Also, the same behaviour if they are locked or unlocked.
          I use mainly SU 2023, in W11.
          None of this happened in SU 2022 (and SU 2023), before the LOTT update to be fully compatible with SU 2024.
          • F
            FlorinAp
            There is no reliable way to set more than 20 columns per palette, fixed (non-scrollable).
            F 1 Reply Last reply
            • F
              FlorinAp @FlorinAp
              I ended up using palettes as toolbars, only because regular toolbars created with LOTT, if undocked, all end up vertically when you restart SketchUp.
              But then i realized that palettes are nicer and cleaner as toolbars, than regular toolbars...
              • O
                optimaforever
                Is there a reason LOTT stopped loading during startup of SU today?
                • fredo6F
                  fredo6
                  Which version do you have?
                  O 1 Reply Last reply
                  • O
                    optimaforever @fredo6
                    @fredo6 2.9C
                    • O
                      optimaforever
                      Ah I've found the culprit. I forgot I had installed an update for D5 Livesync 1.7.0.0001 There seems to be a problem with this one. I rolled back to D5 1.6 and LOTT is back.
                      • T
                        taoklai
                        LOTT stopped working after I installed the latest version of Enscape. I don't know 100% that it's related to Enscape but it's the latest thing I updated and then I realised LOTT is not working at all, no toolbars, nothing. In both SU 2024 and 2025. Can anyone help?
                        • O
                          optimaforever @taoklai
                          @taoklai I had to revert to the previous version of D5 livesync in my case. You should do that with Enscape for a while, until Fredo find a fix.
                          • V
                            VD20
                            https://youtu.be/Wl5v466L04g?t=876
                            create custom command using menu option is not working for me as i wish to create a command button for COPY ALONG CURVE, but the list for selecting the menu is absolutely empty, so searching is also not working. What am i doing wrong?
                            • fredo6F
                              fredo6
                              As of SU2023, the Menu-related features are no longer supported by LOTT. This is due to a change in the GUI framework of Sketchup (called Qt).
                              V 1 Reply Last reply
                              • LinearGraphsL
                                LinearGraphs
                                Hey @fredo6 What am I doing Wrong here? Lol
                                • F
                                  FlorinAp @LinearGraphs
                                  @LinearGraphs You are not doing anything wrong; this happens sometimes.
                                  Change the parameters 2-3 times, and then everything should be back to normal.
                                  • LinearGraphsL
                                    LinearGraphs
                                    I don't know what you mean by changing the parameters, but I had to delete the pallet and import it again for everything to be in working order. All better.
                                    • F
                                      @LinearGraphs I meant parameters of the palette, in palette properties.
                                      • V
                                        VD20 @fredo6
                                        @fredo6 Ok, thanks for replying.
                                        • A
                                          awadrummer
                                          Hi Fredo, per your request here is the post about the conflict I was having between D5 Renderer and LordOfTheToolbars.
                                          Error: Is a directory @ rb_sysopen - .../plugins/d5_converter
                                          The Cause:
                                          LordOfTheToolbars was scanning all plugins to build its toolbar menu. When it encountered the d5_converter folder, it tried to open it as a file to read/copy it, but it's a directory, not a file. This happened in the ghost_command_register function.
                                          The Analysis:
                                          The D5 Converter structure is standard (a .rb loader file + a subfolder with extension code)
                                          Nothing weird about D5's structure
                                          LordOfTheToolbars wasn't properly checking if something is a directory before trying to open/copy it
                                          Summary:
                                          The extension causing the conflict is LordOfTheToolbars. It's failing when scanning the plugins folder because it tries to open the d5_converter directory as if it were a file (using rb_sysopen), triggering the "Is a directory" error. The fix would be adding a directory check before attempting to open/copy files in the ghost_command_register function.
                                          1 Reply Last reply 👍
                                          • V
                                            VD20
                                            I am having an issue with conflict between D5 render live sync plugin.
                                            When the live sync version was D5_LiveSync_Sketchup_usa_1.6.1.0020, there was no issue.
                                            After i update it to D5_LiveSync_Sketchup_usa_1.7.0.0001.
                                            The LOTT vignette strip stopped loading.
                                            I am forced to roll back to older 1.6 version to get the LOTT to load properly.
                                            Kindly look into this issue if possible.
                                            Regards..
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 24 / 27
