    [Plugin] LordOfTheToolbars - v4.0a - 22 Sep 26
    529 Posts 101 Posters 588.5k Views 99 Watching
    • fredo6F
      Can you move the vignette stripe by Click-Drag?
        Ramzix
        Hi @fredo6 pardon my late response. Indeed I can freely move the vingette stripe. However right clicking it does not do anything
          Ramzix
          here the link to see how it behaves on my laptop
          alt text
          • fredo6F
            Do you have several monitors?
            • C
              CGMen
              Hi everyone,
              I’ve noticed some odd behavior in SketchUp 2026.
              If I delete the folder of any Fredo6 plugin — for example, Fredo6_VisuHole — from the SketchUp Plugins directory in Roaming (only the folder, not the main RB/executable file), SketchUp throws the following error on startup:
              “Installation of Fredo6_VisuHole is probably incorrect. Subfolder is missing.”
              What’s strange is that LOTT and Vignette still work fine after this. It doesn’t matter which Fredo6 plugin folder I remove — the same thing happens.
              When I restore the deleted folder, SketchUp starts normally again, but then the behavior becomes the same as what Ramzix described earlier.
                Ramzix
                nope, just a small laptop
                • F
                  FlorinAp
                  There is a very old bug, the Vignette Stripe doesn't stay where you put it - after SU restart, it will reset its position to the default, whether you lock it or not, it will do the same thing.
                  And another one (but i think this one may not have a solution), i have two Favorites Palettes that i use in compact mode as toolbars (horizontal stripes, permanently open), every time you minimize and maximize the SU window, these Palettes navigate about 1-2 mm to the left, until eventually you have to move them back..., and so on.
                  Also, the same behaviour if they are locked or unlocked.
                  I use mainly SU 2023, in W11.
                  None of this happened in SU 2022 (and SU 2023), before the LOTT update to be fully compatible with SU 2024.
                  • F
                    FlorinAp
                    There is no reliable way to set more than 20 columns per palette, fixed (non-scrollable).
                    F 1 Reply Last reply
                    • F
                      FlorinAp @FlorinAp
                      I ended up using palettes as toolbars, only because regular toolbars created with LOTT, if undocked, all end up vertically when you restart SketchUp.
                      But then i realized that palettes are nicer and cleaner as toolbars, than regular toolbars...
                      • O
                        optimaforever
                        Is there a reason LOTT stopped loading during startup of SU today?
                        • fredo6F
                          Which version do you have?
                          O 1 Reply Last reply
                          • O
                            optimaforever @fredo6
                            @fredo6 2.9C
                            • O
                              optimaforever
                              Ah I've found the culprit. I forgot I had installed an update for D5 Livesync 1.7.0.0001 There seems to be a problem with this one. I rolled back to D5 1.6 and LOTT is back.
                              • T
                                taoklai
                                LOTT stopped working after I installed the latest version of Enscape. I don't know 100% that it's related to Enscape but it's the latest thing I updated and then I realised LOTT is not working at all, no toolbars, nothing. In both SU 2024 and 2025. Can anyone help?
                                • O
                                  optimaforever @taoklai
                                  @taoklai I had to revert to the previous version of D5 livesync in my case. You should do that with Enscape for a while, until Fredo find a fix.
                                  • V
                                    VD20
                                    https://youtu.be/Wl5v466L04g?t=876
                                    create custom command using menu option is not working for me as i wish to create a command button for COPY ALONG CURVE, but the list for selecting the menu is absolutely empty, so searching is also not working. What am i doing wrong?
                                    • fredo6F
                                      As of SU2023, the Menu-related features are no longer supported by LOTT. This is due to a change in the GUI framework of Sketchup (called Qt).
                                      V 1 Reply Last reply
                                      • LinearGraphsL
                                        LinearGraphs
                                        Hey @fredo6 What am I doing Wrong here? Lol
                                        • F
                                          FlorinAp @LinearGraphs
                                          @LinearGraphs You are not doing anything wrong; this happens sometimes.
                                          Change the parameters 2-3 times, and then everything should be back to normal.
                                          • LinearGraphsL
                                            LinearGraphs
                                            I don't know what you mean by changing the parameters, but I had to delete the pallet and import it again for everything to be in working order. All better.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 24 / 27
