    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.7k Views 99 Watching
    • O
      optimaforever @fredo6
      @fredo6 2.9C
      • O
        optimaforever
        Ah I've found the culprit. I forgot I had installed an update for D5 Livesync 1.7.0.0001 There seems to be a problem with this one. I rolled back to D5 1.6 and LOTT is back.
        • T
          taoklai
          LOTT stopped working after I installed the latest version of Enscape. I don't know 100% that it's related to Enscape but it's the latest thing I updated and then I realised LOTT is not working at all, no toolbars, nothing. In both SU 2024 and 2025. Can anyone help?
          O 1 Reply Last reply
          • O
            optimaforever @taoklai
            @taoklai I had to revert to the previous version of D5 livesync in my case. You should do that with Enscape for a while, until Fredo find a fix.
            • V
              VD20
              https://youtu.be/Wl5v466L04g?t=876
              create custom command using menu option is not working for me as i wish to create a command button for COPY ALONG CURVE, but the list for selecting the menu is absolutely empty, so searching is also not working. What am i doing wrong?
              • fredo6F
                As of SU2023, the Menu-related features are no longer supported by LOTT. This is due to a change in the GUI framework of Sketchup (called Qt).
                V 1 Reply Last reply
                • LinearGraphsL
                  LinearGraphs
                  Hey @fredo6 What am I doing Wrong here? Lol
                  F 1 Reply Last reply
                  • F
                    FlorinAp @LinearGraphs
                    @LinearGraphs You are not doing anything wrong; this happens sometimes.
                    Change the parameters 2-3 times, and then everything should be back to normal.
                    • LinearGraphsL
                      LinearGraphs
                      I don't know what you mean by changing the parameters, but I had to delete the pallet and import it again for everything to be in working order. All better.
                      • F
                        @LinearGraphs I meant parameters of the palette, in palette properties.
                        • V
                          VD20 @fredo6
                          @fredo6 Ok, thanks for replying.
                            awadrummer
                            Hi Fredo, per your request here is the post about the conflict I was having between D5 Renderer and LordOfTheToolbars.
                            Error: Is a directory @ rb_sysopen - .../plugins/d5_converter
                            The Cause:
                            LordOfTheToolbars was scanning all plugins to build its toolbar menu. When it encountered the d5_converter folder, it tried to open it as a file to read/copy it, but it's a directory, not a file. This happened in the ghost_command_register function.
                            The Analysis:
                            The D5 Converter structure is standard (a .rb loader file + a subfolder with extension code)
                            Nothing weird about D5's structure
                            LordOfTheToolbars wasn't properly checking if something is a directory before trying to open/copy it
                            Summary:
                            The extension causing the conflict is LordOfTheToolbars. It's failing when scanning the plugins folder because it tries to open the d5_converter directory as if it were a file (using rb_sysopen), triggering the "Is a directory" error. The fix would be adding a directory check before attempting to open/copy files in the ghost_command_register function.
                            1 Reply Last reply ๐Ÿ‘
                            • V
                              VD20
                              I am having an issue with conflict between D5 render live sync plugin.
                              When the live sync version was D5_LiveSync_Sketchup_usa_1.6.1.0020, there was no issue.
                              After i update it to D5_LiveSync_Sketchup_usa_1.7.0.0001.
                              The LOTT vignette strip stopped loading.
                              I am forced to roll back to older 1.6 version to get the LOTT to load properly.
                              Kindly look into this issue if possible.
                              Regards..
                              • G
                                gabe05
                                My LOTT broke today. I wanted to add a new extension to my toolbars, and when I clicked on the Master Toolbar Manager button, my vignette stripe disappeared and all my custom toolbars got F'd. Its doubling every button in my custom toolbars, even new toolbars I make, sometimes not even using the correct icon. (They only appear doubled on the toolbar itself and not in the manager.) The stipe is gone, but all my palettes are still available in the Favorites Manager, and I can open them manually. Restarting SketchUp resets the toolbars, but if I open the manager it screws them up again. Can't get the stripe to come back at all. Reinstalling the extension didn't help. v2.9c with sketchup 2018
                                • O
                                  optimaforever @VD20
                                  @VD20
                                  I already reported this error earlier.
                                  • O
                                    optimaforever
                                    May we expect a fix for this issue between D5 render livesync and LOTT?
                                    panixiaP 1 Reply Last reply
                                    • panixiaP
                                      panixia @optimaforever
                                      @optimaforever man, check your n inbox ๐Ÿ‘ป
                                        MarissaW
                                        For some reason while trying to set up my toolbars, my V-Ray tool sets do not show up in the Master Toolbar Manager. It seems like almost everything except that shows up.
                                        Is there something specific I need to do to get it to show?
                                        Using SketchUp 2026, version 26.0.429
                                        Thank you!
                                        fredo6F 1 Reply Last reply
                                        • fredo6F
                                          fredo6 @MarissaW
                                          @MarissaW said:
                                          Thank you!
                                          Nothing you can do. I had to remove VRay from the list of icons because VRay does something to precisely avoid indirect calls (liek LOTT does).
                                            dlannetts
                                            I don't particularly use D5 Render LiveSync, but just wanted to note that I had to remove it for this plugin to function.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 24 / 28
