    [Plugin] LordOfTheToolbars - v3.0a - 21 Apr 26
    503 Posts 96 Posters 466.7k Views 94 Watching
    • fredo6F Offline
      Did you upgrade to LibFredo6 v15.5a.
        Ramzix
        Hey I have Sketchup 2026 problem too. I have newest version of Libfredo 15.5a. My LOTT settings are default.
        1. First button from the left, the one with 9 dots doesn't do anything
        2. This is an old issue when vignette stripe keeps going back to the same left spot on relaunch.
        3. Favorites pop out on the left side of the screen, bigger ones stretch beyond the screen.
        I would be really thankful for any help 😊. I 'd not care that much about LOTT if I had not think this is the extension of them all ;).
        C 1 Reply Last reply Reply Quote 0
          celovito @Ramzix
          @Ramzix
          Same problem here! Fredo help! 🙂
          • fredo6F Offline
            Can you move the vignette stripe by Click-Drag?
              Ramzix
              Hi @fredo6 pardon my late response. Indeed I can freely move the vingette stripe. However right clicking it does not do anything
                Ramzix
                here the link to see how it behaves on my laptop
                alt text
                • fredo6F Offline
                  Do you have several monitors?
                    CGMen
                    Hi everyone,
                    I’ve noticed some odd behavior in SketchUp 2026.
                    If I delete the folder of any Fredo6 plugin — for example, Fredo6_VisuHole — from the SketchUp Plugins directory in Roaming (only the folder, not the main RB/executable file), SketchUp throws the following error on startup:
                    “Installation of Fredo6_VisuHole is probably incorrect. Subfolder is missing.”
                    What’s strange is that LOTT and Vignette still work fine after this. It doesn’t matter which Fredo6 plugin folder I remove — the same thing happens.
                    When I restore the deleted folder, SketchUp starts normally again, but then the behavior becomes the same as what Ramzix described earlier.
                      Ramzix
                      nope, just a small laptop
                      • F Offline
                        FlorinAp
                        There is a very old bug, the Vignette Stripe doesn't stay where you put it - after SU restart, it will reset its position to the default, whether you lock it or not, it will do the same thing.
                        And another one (but i think this one may not have a solution), i have two Favorites Palettes that i use in compact mode as toolbars (horizontal stripes, permanently open), every time you minimize and maximize the SU window, these Palettes navigate about 1-2 mm to the left, until eventually you have to move them back..., and so on.
                        Also, the same behaviour if they are locked or unlocked.
                        I use mainly SU 2023, in W11.
                        None of this happened in SU 2022 (and SU 2023), before the LOTT update to be fully compatible with SU 2024.
                        • F Offline
                          FlorinAp
                          There is no reliable way to set more than 20 columns per palette, fixed (non-scrollable).
                          F 1 Reply Last reply Reply Quote 0
                          • F Offline
                            FlorinAp @FlorinAp
                            I ended up using palettes as toolbars, only because regular toolbars created with LOTT, if undocked, all end up vertically when you restart SketchUp.
                            But then i realized that palettes are nicer and cleaner as toolbars, than regular toolbars...
                            • O Offline
                              optimaforever
                              Is there a reason LOTT stopped loading during startup of SU today?
                              • fredo6F Offline
                                Which version do you have?
                                O 1 Reply Last reply Reply Quote 0
                                • O Offline
                                  optimaforever @fredo6
                                  @fredo6 2.9C
                                  • O Offline
                                    optimaforever
                                    Ah I've found the culprit. I forgot I had installed an update for D5 Livesync 1.7.0.0001 There seems to be a problem with this one. I rolled back to D5 1.6 and LOTT is back.
                                      taoklai
                                      LOTT stopped working after I installed the latest version of Enscape. I don't know 100% that it's related to Enscape but it's the latest thing I updated and then I realised LOTT is not working at all, no toolbars, nothing. In both SU 2024 and 2025. Can anyone help?
                                      • O Offline
                                        optimaforever @taoklai
                                        @taoklai I had to revert to the previous version of D5 livesync in my case. You should do that with Enscape for a while, until Fredo find a fix.
                                        • V Offline
                                          VD20
                                          https://youtu.be/Wl5v466L04g?t=876
                                          create custom command using menu option is not working for me as i wish to create a command button for COPY ALONG CURVE, but the list for selecting the menu is absolutely empty, so searching is also not working. What am i doing wrong?
                                          • fredo6F Offline
                                            As of SU2023, the Menu-related features are no longer supported by LOTT. This is due to a change in the GUI framework of Sketchup (called Qt).
                                            V 1 Reply Last reply Reply Quote 0
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 24 / 26
