    [Plugin] LordOfTheToolbars - v3.0a - 21 Apr 26
    507 Posts 98 Posters 521.7k Views 96 Watching
    • fredo6F
      For the native tools, I did not change the icons. So you get the old ones. I don't think I will update them.
        AISmebel
        Hi Fredo, I installed SketchUp 2026 and I can't click on the import icon to import toolbars. It also didn't work through the menu. Reinstalling the plugin did not help. Is it expected to be compatible with SketchUp 2026?
        • fredo6F
          Did you upgrade to LibFredo6 v15.5a.
            Ramzix
            Hey I have Sketchup 2026 problem too. I have newest version of Libfredo 15.5a. My LOTT settings are default.
            1. First button from the left, the one with 9 dots doesn't do anything
            2. This is an old issue when vignette stripe keeps going back to the same left spot on relaunch.
            3. Favorites pop out on the left side of the screen, bigger ones stretch beyond the screen.
            I would be really thankful for any help 😊. I 'd not care that much about LOTT if I had not think this is the extension of them all ;).
            C 1 Reply Last reply
            • C
              celovito @Ramzix
              @Ramzix
              Same problem here! Fredo help! 🙂
              • fredo6F
                Can you move the vignette stripe by Click-Drag?
                  Ramzix
                  Hi @fredo6 pardon my late response. Indeed I can freely move the vingette stripe. However right clicking it does not do anything
                    Ramzix
                    here the link to see how it behaves on my laptop
                    alt text
                    • fredo6F
                      Do you have several monitors?
                      • C
                        CGMen
                        Hi everyone,
                        I’ve noticed some odd behavior in SketchUp 2026.
                        If I delete the folder of any Fredo6 plugin — for example, Fredo6_VisuHole — from the SketchUp Plugins directory in Roaming (only the folder, not the main RB/executable file), SketchUp throws the following error on startup:
                        “Installation of Fredo6_VisuHole is probably incorrect. Subfolder is missing.”
                        What’s strange is that LOTT and Vignette still work fine after this. It doesn’t matter which Fredo6 plugin folder I remove — the same thing happens.
                        When I restore the deleted folder, SketchUp starts normally again, but then the behavior becomes the same as what Ramzix described earlier.
                          Ramzix
                          nope, just a small laptop
                          • F
                            FlorinAp
                            There is a very old bug, the Vignette Stripe doesn't stay where you put it - after SU restart, it will reset its position to the default, whether you lock it or not, it will do the same thing.
                            And another one (but i think this one may not have a solution), i have two Favorites Palettes that i use in compact mode as toolbars (horizontal stripes, permanently open), every time you minimize and maximize the SU window, these Palettes navigate about 1-2 mm to the left, until eventually you have to move them back..., and so on.
                            Also, the same behaviour if they are locked or unlocked.
                            I use mainly SU 2023, in W11.
                            None of this happened in SU 2022 (and SU 2023), before the LOTT update to be fully compatible with SU 2024.
                            • F
                              FlorinAp
                              There is no reliable way to set more than 20 columns per palette, fixed (non-scrollable).
                              F 1 Reply Last reply
                              • F
                                FlorinAp @FlorinAp
                                I ended up using palettes as toolbars, only because regular toolbars created with LOTT, if undocked, all end up vertically when you restart SketchUp.
                                But then i realized that palettes are nicer and cleaner as toolbars, than regular toolbars...
                                • O
                                  optimaforever
                                  Is there a reason LOTT stopped loading during startup of SU today?
                                  • fredo6F
                                    Which version do you have?
                                    O 1 Reply Last reply
                                    • O
                                      optimaforever @fredo6
                                      @fredo6 2.9C
                                      • O
                                        optimaforever
                                        Ah I've found the culprit. I forgot I had installed an update for D5 Livesync 1.7.0.0001 There seems to be a problem with this one. I rolled back to D5 1.6 and LOTT is back.
                                        • T
                                          taoklai
                                          LOTT stopped working after I installed the latest version of Enscape. I don't know 100% that it's related to Enscape but it's the latest thing I updated and then I realised LOTT is not working at all, no toolbars, nothing. In both SU 2024 and 2025. Can anyone help?
                                          • O
                                            optimaforever @taoklai
                                            @taoklai I had to revert to the previous version of D5 livesync in my case. You should do that with Enscape for a while, until Fredo find a fix.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 24 / 26
