    Animate the path of a panel from a folding door
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    4 Posts 3 Posters 8.1k Views 3 Watching
    • A
      ArgaWoW
      Hello,
      I am have to visualisation the opening of a folding door. The panel have two running gears the must move arround the corner.
      Any Idea how to archive this?
      Thanks a lot for any suggestion 😄
      Arga
      • ntxdaveN
        ntxdave
        I do not have time to try it now but, I think if you use the Animator plugin and capture each of the positions you have in your image as a key frame, you will achieve what you want.
        You might also look in the Animator Beta thread you might see something like what you want ( it is a large thread with a lot of posts) 😄
        Press F1...thank me later
        • ntxdaveN
          ntxdave
          ArgaWoW, I think I have found something that will help you. Look at this thread.
          • HornOxxH
            HornOxx
            Hi - if the desired animation doesn't need to be too sophisticated, a simple gif animation, equipped with some door positions like shown in your picture, might be sufficient? I´ll link an example, done this way with only 10 frames, running back and forth...
            https://sketchucation.com/forums/viewtopic.php?f=397&t=63826&p=659064&hilit=Bobby#p659064
            (otherwise, Dave's animator suggestion above would be better)
            never trust a skinny cook
