    Animate the path of a panel from a folding door
    renderpluginsextensions
    4 Posts 3 Posters 8.0k Views 3 Watching
      ArgaWoW
      Hello,
      I am have to visualisation the opening of a folding door. The panel have two running gears the must move arround the corner.
      Any Idea how to archive this?
      Thanks a lot for any suggestion ๐Ÿ˜„
      Arga
      • ntxdaveN Offline
        ntxdave
        I do not have time to try it now but, I think if you use the Animator plugin and capture each of the positions you have in your image as a key frame, you will achieve what you want.
        You might also look in the Animator Beta thread you might see something like what you want ( it is a large thread with a lot of posts) ๐Ÿ˜„
        Press F1...thank me later
        • ntxdaveN Offline
          ntxdave
          ArgaWoW, I think I have found something that will help you. Look at this thread.
          • HornOxxH Offline
            HornOxx
            Hi - if the desired animation doesn't need to be too sophisticated, a simple gif animation, equipped with some door positions like shown in your picture, might be sufficient? Iยดll link an example, done this way with only 10 frames, running back and forth...
            https://sketchucation.com/forums/viewtopic.php?f=397&t=63826&p=659064&hilit=Bobby#p659064
            (otherwise, Dave's animator suggestion above would be better)
            never trust a skinny cook
