    Holes in a cylinder
    17 Posts 8 Posters 3.4k Views 8 Watching
      Leggie
      Hi I’m trying to draw a 142mm cylinder with it covered in 3mm holes at 5mm centers
      It’s to make a filter basket
      Is there an extension that will help
      Thanks Dean
      • jujuJ Offline
        juju
        Draw the cylinder in an unfolded fashion, draw the holes and array copy as desired, the use the extension "Flowify" to turn it into a cylinder.
          Leggie
          Ok thanks
          • BoxB Offline
            If you work out the logic of the shape you can just use arrays.
            Here I roughly worked out the number of segments needed then created one hole and made two arrays.
            This hole is 1.5mm radius and the face is a 5mm square, and the cylinder is 142mm radius with 168 segments. It's not accurate, you need the correct circumference then divide by the 5mm centers, to get the true number of segments. I just did this by eye.
            That was my guess from your info.
            If you need thickness then I would make the hole with two faces in a wedge format.
            https://i.imgur.com/YeGCYXb.gif
              Leggie
              Hi I managed to draw it by taking one segment of the circle (80 segments), pulling it up to the length and cutting the holes in that
              50 holes per segment
              Then I copied and rotated it 80 times, so now we have 4000 holes
              It was scaled up x10, I tried to scale it back down but got the spinning beach ball and it just froze up
              Any idea how to clean it up
              • BoxB Offline
                Use the bare minimum of segments for your holes.
                  Leggy
                  the file is too big to send
                  • BoxB Offline
                    I'm not sure why you want to send it.
                    Just start again and use fewer segments in the circles for the holes, and be patient, doing anything with 4000 holes can take time.
                    And I'm off to bed.
                    By the way, how many users accounts do you have?
                      Leggie
                      I’m on the minimum
                      Only one account
                      • BoxB Offline
                        What is the minimum?
                        How can you only have one and yet you are leggie in one post and leggy in another.
                        • pbacotP Offline
                          And I'm off to bed.
                          As they found out in Blackburn, Lancashire.
                            Leggy
                            I signed into my iPad and forgot which way it was spelt
                            24 segments
                              Fortunately I'd finished my coffee before reading that.
                              • BoxB Offline
                                24 is the default not the minimum. You could use as few as 8 and still have the appearance of a smooth circle. The minimum is 3.
                                • GD3DesignG Offline
                                  GD3Design
                                  @pbacot said:
                                  And I'm off to bed.
                                  • BoxB Offline
                                    Just to keep you all happy.
                                      slbaumgartner
                                      Good thing the holes were very small!
