    Holes in a cylinder
    17 Posts 8 Posters 3.5k Views 8 Watching
    • BoxB
      If you work out the logic of the shape you can just use arrays.
      Here I roughly worked out the number of segments needed then created one hole and made two arrays.
      This hole is 1.5mm radius and the face is a 5mm square, and the cylinder is 142mm radius with 168 segments. It's not accurate, you need the correct circumference then divide by the 5mm centers, to get the true number of segments. I just did this by eye.
      That was my guess from your info.
      If you need thickness then I would make the hole with two faces in a wedge format.
      https://i.imgur.com/YeGCYXb.gif
      • L
        Leggie
        Hi I managed to draw it by taking one segment of the circle (80 segments), pulling it up to the length and cutting the holes in that
        50 holes per segment
        Then I copied and rotated it 80 times, so now we have 4000 holes
        It was scaled up x10, I tried to scale it back down but got the spinning beach ball and it just froze up
        Any idea how to clean it up
        • BoxB
          Use the bare minimum of segments for your holes.
          • L
            Leggy
            the file is too big to send
            • BoxB
              I'm not sure why you want to send it.
              Just start again and use fewer segments in the circles for the holes, and be patient, doing anything with 4000 holes can take time.
              And I'm off to bed.
              By the way, how many users accounts do you have?
              • L
                Leggie
                I’m on the minimum
                Only one account
                • BoxB
                  What is the minimum?
                  How can you only have one and yet you are leggie in one post and leggy in another.
                  • pbacotP
                    And I'm off to bed.
                    As they found out in Blackburn, Lancashire.
                    • L
                      Leggy
                      I signed into my iPad and forgot which way it was spelt
                      24 segments
                        Fortunately I'd finished my coffee before reading that.
                        • BoxB
                          24 is the default not the minimum. You could use as few as 8 and still have the appearance of a smooth circle. The minimum is 3.
                          • GD3DesignG
                            GD3Design
                            @pbacot said:
                            And I'm off to bed.
                            • BoxB
                              Just to keep you all happy.
                                slbaumgartner
                                Good thing the holes were very small!
