    2.2k Posts 487 Posters 936.4k Views 492 Watching
      brittico Newcomers
      Can't validate Fredo Portrait License
      Hello please need help, just purchased the license but it doesnt work, have read all the help solutions but nothing works. It says "sorry an error occured in the communication with sketchucation. I have internet, all is work. please help, this extension is vital for my work
        Rich O Brien Moderator @brittico
        @brittico said in SCFLicense: Extension Licensing on Sketchucation:
        This can be the result of a strict network policy. Please whitelist:
        *.sketchucation.com
        Our try switching to a less strict network.
          brittico Newcomers
          Hi, thanks for reply, how to whiteliste? the network is my own private one.
          TIGT 1 Reply Last reply Reply Quote 0
            TIG Moderator @brittico
            @brittico
            Your Firewall has a list of sites it prevents access to - a 'blacklist'.
            There is a 'whitelist' of sites that are allowed.
            Manage your Firewall and add *.sketchucation.com to that...
            B 1 Reply Last reply Reply Quote 1
              brittico Newcomers
              I am on microsoft defener, is it a file, folder, file type or process, sorry for the dump questions but I am not a pro on the pc, thanks
                brittico Newcomers @TIG
                @TIG have whitelisted it as a "file type", also switched of defender, tried it again, and again, no luck, have the same problem with "round corner" which was already working as I bought the license back in march.
                TIGT Rich O BrienR 2 Replies Last reply Reply Quote 0
                  @brittico
                  Are there other options like 'url' ?
                  The string given is not a file-type...
                    @brittico
                    Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                    B 2 Replies Last reply Reply Quote 0
                      brittico Newcomers @Rich O Brien
                      @Rich-O-Brien Fredo6 Plugins Information on 2024-07-06 16:50:40 +0100
                      • Platform: x64-mswin64_140 - Ruby: 3.2.2
                      • Sketchup: 24.0.553
                      • LibFredo6: v14.5c
                      • LibFredo6 Binary loaded
                      • Sketchucation ExtensionStore: 4.4.1
                      • SCFLicense: v6.4a - 74
                      • Fredo6 Plugins
                        Curviloft v1.9b
                        FredoPortrait v2.9a
                        RoundCorner v3.4a
                      • SCFLicense directory present
                        Signature File: 2024-07-04 16:41:09 +0100
                        RoundCorner: 2024-03-04 10:02:47 +0000
                        @Rich-O-Brien I have just found out none of my Fredo Extensions are working anymore, Curvy Loft and Round Corner are Extensions which I was already working with as I bought the license but now none of them are working, they are all telling me that I need to get a license and when trying to activate I get the same message for all three extensions.
                          @brittico Please follow the steps in my previous reply.
                            Please share the error messages. If it’s network related as it has been previously please change networks or whitelist
                            The more concise information you share in terms of error messages the sooner we can paint a picture of what is going on.
                            Also make sure you are using the latest versions of all extensions. This can be checked in SketchUcation Tools
                            • P Offline
                              parkjh1477
                              I have a activate problem with purchased license. anyone help me? ㅠ
                                TIG Moderator @parkjh1477
                                @parkjh1477
                                The error message means the signature file can't be read.
                                You can follow the instructions and delete the file [folder opens on button click], then re-validate the licenses and see if that helps...
                                This can happen if you change the name of your computer, it can also be affected if you have computer name that doesn't follow the Windows rules - e.g. the computer's name contains special characters causing issues with the licensing system saved data...
                                Let us know how you get on...
                                P 2 Replies Last reply Reply Quote 0
                                • P Offline
                                  parkjh1477 @TIG
                                  @TIG
                                  I tried changing the computer name, but it didn't solve the problem. However, the license for SketchUp 2021 version on the same computer works normally. Should I delete SketchUp 2021?
                                  • P Offline
                                    parkjh1477 @TIG
                                    @TIG
                                    I tried changing the computer name, but it didn't solve the problem. However, the license for SketchUp 2021 version on the same computer works normally. Should I delete SketchUp 2021? (i'm using ver.2024)
                                      @parkjh1477
                                      Both versions can exists side-by-side, so don't delete v2021 just yet.
                                      Does your computer-name follow the Windows rules - i.e. no special characters...
                                      This is a range of characters that can be considered safe:
                                      Letters (a-z A-Z)
                                      Digits (0-9)
                                      Underscore (_)
                                      Hyphen (-)
                                      Space
                                      Dot (.)
                                      Beyond this, you just have to enforce some additional rules regarding spaces and dots. This is usually sufficient:
                                      Name must contain at least one letter or number (to avoid only dots/spaces)
                                      Name must start with a letter or number (to avoid leading dots/spaces)
                                      Name may not end with a dot or space
                                      Do you have any special characters in the computer-name OR your user-name ? - I guess you are Korean ?
                                      • P Offline
                                        parkjh1477 @TIG
                                        @TIG Yes, I am korean. I fixed my problem following your advise. Really thank you for your kindness reply. Thanks!
                                        • N Offline
                                          November11 Newcomers
                                          Please tell me how to solve the problem??
                                            TIG Moderator @November11
                                            @November11
                                            Follow the message's instructions on opening the folder and deleting the file.
                                            You might need to rename your computer...
                                            Your computer-name must follow the Windows rules - i.e. NO special characters in it...
                                            Letters (a-z A-Z)
                                            Digits (0-9)
                                            Underscore (_)
                                            Hyphen (-)
                                            Space
                                            Dot (.)
                                            Do you have any special characters in the computer-name OR your user-name ? - I guess you are Chinese ?
                                            Try fixing that and restart to see if that helps...
                                            • 93
                                            • 94
                                            • 95
                                            • 96
                                            • 97
                                            • 109
                                            • 110
                                            • 95 / 110
