    2.3k Posts 514 Posters 1.6m Views 519 Watching
    • John SBJ Offline
      John SB
      Success!
      Hi Rich
      That was the trick. Thanks again.
      • N Offline
        numerobis
        @moonsrfr said:
        Ok. I bought Fredo's bundle, got 8 emails, each with a licensing file in it
        So it's 8 individual licenses and not one bundle license? And all licenses need to be checked every few days? (5 days? 7 days?). So there must be a permanent connection to the internet?
          Yes
          The license does ping occasionally. Unsure of the time frame though. Fredo would know more.
          Not really. Tools will work offline if you validated while online.
            Have you installed the latest version of Lib Fredo and restarted SketchUp ?
            • fredo6F Offline
              fredo6
              Normally, LibFredo6 v12.8a should solve this problem.
              • ely862meE Offline
                ely862me
                Yes, latest LibFredo installed trough the Extension Store 4.2.5.
                The other license extensions are working fine. Actually I just activated Curvizard and it worked once and then it said the same as the scale. They work only once after startup, then the Trial Period Expired window appear.
                So it is something that started today. Both of these licenses I inserted today!
                Elisei (sketchupper)
                Come and See EliseiDesign
                  Serje89
                  I have the same problem like ely862me
                  • ely862meE Offline
                    ely862me
                    Hi!
                    First thank you for the Fredo6Bundle! It is great. I only saw their importance when I couldn't use them anymore!
                    I purchased* the bundle and inserted a couple of licenses but today after FredoScale expired I successfully inserted the license yet when I try to use it is says it expired.
                    I have reinstalled the plugin and it gives this error. It gets installed and looks alright though.
                    EDIT:
                    I have uninstalled the other Sketchup versions and removed the FredoScale plugin from the Plugins Folder. Now there is no error at installation. So that error was meaningless regarding the license problem.
                    *Rich knows
                    • pep75P Offline
                      pep75
                      Same problem here suddenly..Updated everythingbut still can't get it to work...Everything seems to be fine but everytime I want to use the plugin I got the license message.
                        There was a recent report of similar issues, traced to a server-side issue.
                        This was fixed and affected licensees were issue new details.
                        However, these reports suggest that an issue still persists...
                        I'm sure the IT team are investigating and working on a fix !
                        • ely862meE Offline
                          ely862me
                          Nasty stuff when we are depending on servers.
                          I was working hourly and I had to stop the job because I couldn't use it and finish it.
                          Hope it gets fixed soon!
                          Thanks to those working under radar!
                          • G Offline
                            Gábor
                            When you go to your Extensions / SketchUcation / SCFLicence : Global Status what do you see? Are the plugins licensed?
                              I just validated your license on my system...
                              https://i.imgur.com/u8JRWuc.png
                              ...how do you get it to fail? For me it works
                              • G Offline
                                Gábor
                                @ely862me said:
                                Round corner and FredoCorner work!
                                JPP works
                                Curviloft works
                                TOS works.
                                Curvizard and FredoScale I activated today also VisuHole and TopoShaper, and they are not working.
                                Ah, I saw two seats there, I thought might be because there is RoundCorner and FredoCorner.
                                Could you please release the license one of the not working ones and re-activate, restart SketchUp and try again?
                                • ely862meE Offline
                                  ely862me
                                  Round corner and FredoCorner works
                                  JPP works
                                  Curviloft works
                                  TOS works
                                  Curvizard and FredoScale I activated today. Also VisuHole and TopoShaper, and they are not working.
                                  Something happened from yesterday to today. What I activated today won't work!
                                  • ely862meE Offline
                                    ely862me
                                    I already did that, it didn't work!
                                    Hey! I don't know what you did but now they seem to work! Yay!
                                    • G Offline
                                      Gábor
                                      Good to hear that it is working now. Could everybody with the same problem retry it now?
                                      • G Offline
                                        Gábor
                                        Could you please reactivate the not working licenses, restart SketchUp and try to use the affected plugins again?
                                        • G Offline
                                          Gábor
                                          Could you please reactivate the not working licenses, restart SketchUp and try to use the affected plugins again and tell us the result?
                                            Serje89
                                            Work without restart. Thx!!!
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 115
                                            • 116
                                            • 12 / 116
