    2.3k Posts 502 Posters 1.1m Views 507 Watching
      Following on from @fredo6 's comment...
      If each user logs in separately then surely a simple cmd script [written by your IT guys] auto-running at their login, could copy the needed license files over into their '../appdata/local/scf licenses' directory. Having this consistent location set up for everyone's folders/files should ease the license reading / validation ? Perhaps a logout cmd script could also run to tidy up and remove the no longer needed files, if thought appropriate ? ...
      R 1 Reply Last reply Reply Quote 0
        Ramon3D @fredo6
        @fredo6
        I think this is exactly the problem indeed. It would be fantastic if this could be adjusted. We work in the computer lab on Windows 11.
          Ramon3D
            Ramon3D @TIG
            @TIG
            One of the ICT staff members has tried this, but so far it has not been successful.
              Step by step questions...
              Can your IT guy get a cmd script to run at user's login ?
              Can your IT guy then make that cmd script copy the license files from an admin-account's folder-structure into an equivalent folder in the user's account - e.g. '../appdata/local/scf licenses' ?
              If this happens why can't the user then see the expected license files ?
              I'm no cmd script guru. but surely your IT guys have some helpful ideas ??
              e.g. If you manually copy over the license files from an admin-account's folder-structure into an equivalent folder in the user's account - e.g. '../appdata/local/scf licenses' - does that then work as expected ? If not, then why not ?
                Ramon3D @TIG
                @TIG
                Thank you TIG,
                I have just forwarded your information and the ICT colleagues will take a look at it. I’m not a CMD script guru myself either, so hopefully they can work with this information. As soon as I hear more from them, I’ll let you know so I can answer your questions.
                @fredo6, do you see any possibility to modify the custom directory?
                  Cold Camuck
                  Hello.
                  I've been using Fredo Corner for a number of years (currently using version 2.7a) in SketchUp 2017, but never had an issue like this. After doing a full wipe and clean install of windows 10, I attempted to reinstall all of the usual extensions, but the Fredo Corner extension keeps giving me a license error, saying that because it isn't licensed due to having too many seats using it, I must purchase the paid version, to make up the difference, or words to that effect. I just rechecked and redownloaded the extension and license , but it continues to state that there are too many seats using it, guy I'm the only person in my family using Sketchup or the extension, so I have no way of explaining why this type of error is happening.
                  Any ideas?
                    Rich O Brien Moderator @Cold Camuck
                    Can you release seats at https://sketchucation.com/webshop/my-licences.php?
                      Cold Camuck
                      Damn, that was fast (that's what she said.....sorry, old joke), but I do appreciate your speedy resolution.
                      Cheers, eh.
                      CC
                        jaroslavz
                        Hi Fredo6.
                        Can you please release my fredo6 round corner|plugin license?
                        53819 RoundCorner RoundCorner Perpetual License Unlimited 29/04/2022 1 / 3
                        Seats:
                        Seat ID: 248896; HW ID: TD1729675210.0E; Date of activation: 19/08/2025
                        Thank you.
                          Rich O Brien Moderator @jaroslavz
                          Can you not release seats at https://sketchucation.com/webshop/my-licences.php ?
                            jaroslavz
                              @jaroslavz said:
                              Sorry, I can't
                              Please check https://sketchucation.com/webshop/my-licences.php
                              You need your device/s to run Sketchucation Tools 5.0: https://sketchucation.com/plugin/696-sketchucationtools
                              This enables online releasing.
                                jaroslavz
                                thank you for your quick reply. Everything is now ok. Thank you
                                • W Offline
                                  whitelock
                                  how do I take seats off my license I only have two machines and it says ive exceeded my three seats
                                    Can you release at the devices or online?
                                    • O Offline
                                      omni
                                      Hello, I purchased software under my personal account. Can I use it on a company computer for commercial use?
                                        @omni
                                        What software do you mean ?
                                        O 1 Reply Last reply Reply Quote 0
                                        • H Offline
                                          Haikal151 Newcomers
                                          Fredo..can u help me with this?
                                            Rich O Brien Moderator @Haikal151
                                            @Haikal151
                                            Install Sketchucation Tools: https://sketchucation.com/plugin/696-sketchucationtools
                                            Restart SketchUp after installation and activate license.
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 113
                                            • 112 / 113
