    2.3k Posts 515 Posters 2.1m Views 520 Watching
    • TIGT Online
      Following on from @fredo6 's comment...
      If each user logs in separately then surely a simple cmd script [written by your IT guys] auto-running at their login, could copy the needed license files over into their '../appdata/local/scf licenses' directory. Having this consistent location set up for everyone's folders/files should ease the license reading / validation ? Perhaps a logout cmd script could also run to tidy up and remove the no longer needed files, if thought appropriate ? ...
      R 1 Reply Last reply Reply Quote 0
        Ramon3D @fredo6
        @fredo6
        I think this is exactly the problem indeed. It would be fantastic if this could be adjusted. We work in the computer lab on Windows 11.
          Ramon3D
          This post is deleted!
            Ramon3D @TIG
            @TIG
            One of the ICT staff members has tried this, but so far it has not been successful.
            • TIGT Online
              Step by step questions...
              Can your IT guy get a cmd script to run at user's login ?
              Can your IT guy then make that cmd script copy the license files from an admin-account's folder-structure into an equivalent folder in the user's account - e.g. '../appdata/local/scf licenses' ?
              If this happens why can't the user then see the expected license files ?
              I'm no cmd script guru. but surely your IT guys have some helpful ideas ??
              e.g. If you manually copy over the license files from an admin-account's folder-structure into an equivalent folder in the user's account - e.g. '../appdata/local/scf licenses' - does that then work as expected ? If not, then why not ?
                Ramon3D @TIG
                @TIG
                Thank you TIG,
                I have just forwarded your information and the ICT colleagues will take a look at it. I’m not a CMD script guru myself either, so hopefully they can work with this information. As soon as I hear more from them, I’ll let you know so I can answer your questions.
                @fredo6, do you see any possibility to modify the custom directory?
                  Cold Camuck
                  Hello.
                  I've been using Fredo Corner for a number of years (currently using version 2.7a) in SketchUp 2017, but never had an issue like this. After doing a full wipe and clean install of windows 10, I attempted to reinstall all of the usual extensions, but the Fredo Corner extension keeps giving me a license error, saying that because it isn't licensed due to having too many seats using it, I must purchase the paid version, to make up the difference, or words to that effect. I just rechecked and redownloaded the extension and license , but it continues to state that there are too many seats using it, guy I'm the only person in my family using Sketchup or the extension, so I have no way of explaining why this type of error is happening.
                  Any ideas?
                    Rich O Brien Moderator @Cold Camuck
                    Can you release seats at https://sketchucation.com/webshop/my-licences.php?
                      Cold Camuck
                      Damn, that was fast (that's what she said.....sorry, old joke), but I do appreciate your speedy resolution.
                      Cheers, eh.
                      CC
                        jaroslavz
                        Hi Fredo6.
                        Can you please release my fredo6 round corner|plugin license?
                        53819 RoundCorner RoundCorner Perpetual License Unlimited 29/04/2022 1 / 3
                        Seats:
                        Seat ID: 248896; HW ID: TD1729675210.0E; Date of activation: 19/08/2025
                        Thank you.
                          Rich O Brien Moderator @jaroslavz
                          Can you not release seats at https://sketchucation.com/webshop/my-licences.php ?
                            jaroslavz
                              @jaroslavz said:
                              Sorry, I can't
                              Please check https://sketchucation.com/webshop/my-licences.php
                              You need your device/s to run Sketchucation Tools 5.0: https://sketchucation.com/plugin/696-sketchucationtools
                              This enables online releasing.
                                jaroslavz
                                thank you for your quick reply. Everything is now ok. Thank you
                                • W Offline
                                  whitelock
                                  how do I take seats off my license I only have two machines and it says ive exceeded my three seats
                                    Can you release at the devices or online?
                                    • O Offline
                                      omni
                                      Hello, I purchased software under my personal account. Can I use it on a company computer for commercial use?
                                      • TIGT Online
                                        @omni
                                        What software do you mean ?
                                        O 1 Reply Last reply Reply Quote 0
                                        • H Offline
                                          Haikal151 Newcomers
                                          Fredo..can u help me with this?
                                            Rich O Brien Moderator @Haikal151
                                            @Haikal151
                                            Install Sketchucation Tools: https://sketchucation.com/plugin/696-sketchucationtools
                                            Restart SketchUp after installation and activate license.
                                            • 110
                                            • 111
                                            • 112
                                            • 113
                                            • 114
                                            • 115
                                            • 116
                                            • 112 / 116
