    Problem object!!
    16 Posts 4 Posters 5.9k Views 4 Watching
      JohnMGD
      Hi all, I have a problem with an object I am creating, this is a Range Finder cove for a Gun turret, 95% of the cove is ready but I don't get the angled part of cove not rounded and smoothed to the rest of the cove, any ideas ????
        Is this what you are trying to accomplish?
        Follow Me works quickly for this.
        FWIW, I moved your thread from Tutorials because you weren't posting a tutorial.
          JohnMGD
          Thanks for this solution, will try it immediately !!! πŸ‘ πŸ‘ πŸ‘
            JohnMGD
            Hi, I tried the "follow Me" tool, on the left side of the cove it worked but the front side of the cove must be straight an at an angle 90 degrees, see red lines.
              slbaumgartner
              That looks like you bent the path in the wrong plane - sidways instead of vertically.
              • BoxB Offline
                I think we need an image of the object you are trying to create to fully understand. Looks like it could just be a but of pushpull then move with alt.
                  JohnMGD
                  Thanks, this is exactly how it should be, will try it myself !! πŸ˜„
                    JohnMGD
                    I succeeded in the last task shown hear, but now I hit another wall and have the following problem, I like to Subtract the solid (in between blue lines) from the hollow Range Finder cove, so that an opening appears in the Rang Finder cove.
                    I made both objects a group, only the blue lined object seems to be solid, but it must be possible some how to make this opening in the Range Finder cove.
                    Can anyone tell me how to proceed ??
                    Put another screenshot here, the bottom and front part must also be open:
                    And what I also miss is the thickness of the plate must be shown !!
                    • BoxB Offline
                      The cove has no inner face, you can see the blue/gray of the back face, you need to have thickness for it to be a solid.
                      However, you can select the faces of the cove and Intersect Faces with Model to achieve the cutting edges.
                      It would help if you attached your model so we can see better what you have.
                        JohnMGD
                        Here is the original file:
                        And I tried to intersect faces of the model, but got this message:
                        Test.skp
                        • BoxB Offline
                          It's easier to redraw your shape with the inner face intact than it is to replace the missing face.
                            JohnMGD
                            Thanks a lot Box, do you have any idea how I can save your little videos, for watching them later ??
                            • BoxB Offline
                              Intersect Faces with ... is the long hand way of doing things that solid tools can do.
                              You need to be in the correct context and make the correct choice but, basically it needs to have something to intersect with.
                              Like this.
                              • BoxB Offline
                                You can right click on the gif and choose, 'Save Image as' to you computer and it should open in any browser and many image editors or viewers.
                                  JohnMGD
                                  Thanks a lot for your tutorials and tip for saving these. I also have another question, what my problem is, why can't I find these solutions on my own, which tutorials did you follow to get that good in SketchUp !! I am busy with this model of the Gun Turret now for three weeks and don't make any progress, only the solutions you sent me, in real you are building my model not I 😞
                                  • BoxB Offline
                                    The sketchup campus is a good place to start.
                                    https://learn.sketchup.com/
                                    Plus the Sketchup Youtube Channel.
                                    I originally followed Sketchup for dummies on youtube by aiden chopra.
