    Help of Installing Fredo6 Plugin
    5 Posts 5 Posters 3.2k Views 5 Watching
      For Help Fredo maybe you must give the Name of the Fredo Plugin that you want to load...or Library
      • S
        slbaumgartner
        @kirklee14 said:
        Hi all,
        I was trying to download the Fredo6 plugin after following the recommended steps. However, the plugin ended up with a list of codes instead of the expected plugin icons, does anyone know how to fix this ?
        What mechanism were you trying to use to download the plugin? The screenshot you posted appears to show the contents of a javascript file meant to be loaded by the Fredolib, not anything you should be seeing directly.
          @kirklee14 said:
          ...after following the recommended steps.
          What exactly are the "recommended steps" you followed?
          • TIGT
            Most of Fredo's Extensions also require his 'Lib' installing...
            Download that, install and restart SketchUp to sync everything...
            It's odd to see the window with Javascript in it ?
            How did you try to launch the Fredo Tools ?
            • J
              jonayabascal
              Thanks for the advice, helped a lot. Faced this problem myself.
