Help of Installing Fredo6 Plugin
For Help Fredo maybe you must give the Name of the Fredo Plugin that you want to load...or Library
@kirklee14 said:
Hi all,
I was trying to download the Fredo6 plugin after following the recommended steps. However, the plugin ended up with a list of codes instead of the expected plugin icons, does anyone know how to fix this ?
What mechanism were you trying to use to download the plugin? The screenshot you posted appears to show the contents of a javascript file meant to be loaded by the Fredolib, not anything you should be seeing directly.
@kirklee14 said:
...after following the recommended steps.
What exactly are the "recommended steps" you followed?
Most of Fredo's Extensions also require his 'Lib' installing...
Download that, install and restart SketchUp to sync everything...It's odd to see the window with Javascript in it ?
How did you try to launch the Fredo Tools ? -
Thanks for the advice, helped a lot. Faced this problem myself.
